Retail availability of Byrd knives?
Are their any retail chains that carry Byrd knives? I'd like to take a look at the different models to decide on what I might like to get.
- spoonrobot
I've actually found two of the three that I own in the little "bargain bins" at the local B&M knife shops... a lot of high end places that generally retail 100$ plus blades stick everything worth less than about 40$ together. If you don't mind rooting around through a bunch of frost cutlery and cheap chinese pieces of crap, you can find some real gold in there. The only other way I've found one is online. You might just have to put in the legwork (knife shops, sharpening places, pawn shops and such) to actually handle multiple models pre-purchase. Good luck, no matter how you get one you won't be dissappointed.
Don't hit at all if it is honorably possible to avoid hitting; but never hit soft.
- Theodore Roosevelt
"I twisted the knife until I heard his heart-strings sing."
- Jim Bowie concerning Maj. Norris Wright
You could also just buy from a dealer with a quick and easy returns policy, like Lighthound.com, in case you end up disliking a certain knife.
I'm lucky -- I live in Denver and can go handle new models at the Spyderco Outlet Store. :D
I think the older models may be the ones in the blister packs. Both of my G10 Cara Cara's and G10 Meadowlark came in boxes. One of my Flights came in a box and one came in a blister pack. The 2 Flights are different in the fact that the one that came in the box had Taiwan on the blade, in much smaller letters, probabaly 1/2 the size as the ones on the blade of the one that came in the blister pack. The smaller letters are the same size as my other Byrds. However, the one with the larger Taiwan on the blade from the blister pack, had much smoother blade action then the newer boxed model.
Regards Sonny
Regards Sonny
Fender Strat...the Guitar that put the Rock in Rock&Roll
