I want my Yo waved
merciful
I want my Yo waved
Post by merciful »
I've never tried a waved blade, but the idea has fascinated me. Lately, I've been carrying my Yojimbo to draw into reverse grip, which requires an inertial opening. It's pretty quick, but does require a bit of coordination and no matter how often I practise the draw, I don't think I'll be absolutely sure of it coming off under pressure. So after seeing the removable wave on the P'kal (in markg's P'kal review), I improvised a very temporary mod to the Yo (wadded up some tinfoil to fit the hole, stuck a finish nail into the foil at the right angle): and it worked every time.
I wonder if STR could retrofit removable wave add-ons to other knives? The angled pin seems to me to be a more sure way of catching the front of a pocket than grinding away part of the Yo's blade. I guess it'd require drilling a threaded hole into the blade to accept the attachment, but I haven't had a look at a P'kal to say for sure.
Those who give up their freedom for safety will soon find that they have neither.[SIZE="-1"][/size]
krazichinaman
Post by krazichinaman »
merciful wrote:I've never tried a waved blade, but the idea has fascinated me. Lately, I've been carrying my Yojimbo to draw into reverse grip, which requires an inertial opening. It's pretty quick, but does require a bit of coordination and no matter how often I practise the draw, I don't think I'll be absolutely sure of it coming off under pressure. So after seeing the removable wave on the P'kal (in markg's P'kal review), I improvised a very temporary mod to the Yo (wadded up some tinfoil to fit the hole, stuck a finish nail into the foil at the right angle): and it worked every time.
Have you tried to use a zip-tie in the spyder hole? Works wonders. If you want, you can always use a dremel to make your own wave. I've done a few for myself and it isnt all that bad.
________
IPAD CASES
________
California medical marijuana
merciful
Post by merciful »
Thanks, Krazi: I haven't tried the zip yet, but I will. The dremel-ed option doesn't strike me as quite as likely to catch every time as the angled pin: have a look at how it sits on the P'kal and see what I mean. Maybe I'm wrong, anyway, but I'm not sure I want to grind a chunk off the Yo to find out.
CombatGrappler
Post by CombatGrappler »
Just ask STR yourself. He has his own forum at BladeForums.com now.
merciful
Post by merciful »
Hey, thanks. I would have gotten around to a PM soon enough, but that's cool to know about his forum.
CombatGrappler wrote:Just ask STR yourself. He has his own forum at BladeForums.com now.
Bassman
Post by Bassman »
In order to put a stud in the blade, you need to drill a hole in the spine, which is, as far as human are concerned, impossible to do with any precision without annealing the blade. (anneal = making the steel soft as before heat treatment) Even if you could drill a hole, threading it would definitely break the tap. ANYWAY, if you did get someone to anneal it, and got someone to drill and tap a hole in it, then you'd still have to have it re-heat treated back to Rc 59-61 to be like it was before :-) after paying for all of that, you might as well buy a P'kal :D
merciful
Post by merciful »
Thanks, Bassman. I haven't seen a pic that shows exactly where the stud is in the P'kal: are you sure it's in the spine and not the side of the blade? It might not matter much, anyway, the project still might not be feasible.
Stenny
Post by Stenny »
It is in the spine.
...but no, no, you know it all, it's harmless little bunny...
merciful
Post by merciful »
Well, there ya go: I haven't bought a knife in a month or so, anyway. To the dealer!
Stenny wrote:It is in the spine.
So-Lo
Post by So-Lo »
Thanks for the info, I didn't know this untill now. :cool:
Michael Cook
Post by Michael Cook »
:spyder: Buy a waved rescue, delica, or endura first. They're inexpensive and you'll find out if you like the wave or not without messing up your yo. :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
Michael Cook
:spyder: here's some pics of someone's waved yo (not mine, alas!) :spyder:
merciful
Post by merciful »
Thanks, Michael. Those are the very pics that got me started on the idea. I'm questioning doing that to my Yo, because I've got a feeling that the pin on the P'kal is more likely to catch firmly on the front of my jeans pocket when drawn into a reverse grip, since it sticks out more. Others have pointed out the potential disadvantages of the P'kal style of wave, but since I don't carry anything in my RF pocket but a knife (since I discovered a quarter stuck in the Yo that caused it not to open), and so don't have any reason to be reaching around in there, I don't think it'd bother me.
Michael Cook wrote: :spyder: Buy a waved rescue, delica, or endura first. They're inexpensive and you'll find out if you like the wave or not without messing up your yo. :spyder:
So-Lo
Post by So-Lo »
Michael Cook wrote: :spyder: here's some pics of someone's waved yo (not mine, alas!) :spyder:
I waved and blasted this Yo, and also took the pics, and posted them. :D
Thanks, for all the kind words, it does work great!
merciful
Post by merciful »
You should indeed be happy with the work.
Have you tried it so that it catches the front of the pocket, and draws into reverse grip?
So-Lo Kustoms wrote:I waved and blasted this Yo, and also took the pics, and posted them. :D
So-Lo
Post by So-Lo »
It would take some practice to get it to open 100% of the time. I do feel it could be done, I however do not really care for a waved knife. Just give me a hole and I'm happy :D
:p
I do think the Yojimbo is the best looking waved knife I have ever seen, BUT I may be biaist! :)
merciful
Post by merciful »
Thanks. The silly temporary home-made version of the P'kal-style wave I tried on my Yo worked flawlessly every time I tried it, so I think the P'kal may be for me.
Anyway, there are very few ways that owning another Spydie could be a bad thing. None are coming to mind right now.
CRS
Post by CRS »
After reading the title of this thread, I was thinking...THAT'S GOTTA BE PAINFUL :eek: :eek: :eek:
CRS
An invitation to visit my Photography Galleries at:
http://www.pbase.com/crs
