torx bit sizes...
torx bit sizes...
hey there, my delica BRG PE is pretty tight, and id like to loosen it a tiny bit. Just wondering the size of the bit i need. Im guessing its 8 but i wanted to double check, thanks
- Simple Man
Listen to the man...this is an important bit of into for those trying to adjust play on a blade. After several years, I did this with a Millie and it makes a world of difference.Mr Blonde wrote:Depends on which screw you want to loosen. The pivot can be adjusted with a T8 driver and all other screws can be tuned with a T6 driver. The reason I mention both is that I've had good results with adjusting the action by -carefully- adjusting the pin closest to the pivot pin.
Wouter
Romans 8:31 ....If God is for us, who can be against us? - <><
The Spyderco hole is a rotating mechanical assembly of one part.
".....tractors don't have to look like Ferraris" -Sal
here's some extra info on tools for knife nuts.
what you usually need to have when you want to adjust knives or tinker with them, or well, whatever:
Torx:
T6
T8
T10
T15
T20
Allen ("Inbus" in Europe):
basically all sizes ranging from 1mm to 8mm approx.
make sure to have a European and a USA_SAE-International set
European sizes are in mm's, eg. a 3mm
SAE is in inches, like a 3/32"
Philips-heads:
#1 through #4 approx
Flat-heads:
something like 1 through 6mm
a pair of pliers, a vice, a cloth and a hammer are nice to have too. and plenty of other crap i forgot to mention right now.....
denn
Torx:
T6
T8
T10
T15
T20
Philips-heads:
Flat-heads:
denn
