[CENTER]
Yes! Thanks Rob, I should have noted which was which.Rob wrote:I guess the one with the stripes is the tooth? Stunning, absolutely stunning!
Cheers, Rob
If Sal decides to go through with a LH Kopa, and the scale material he elects to use on it is something that can be removed as easily as the jigged bone on the Kiwis, I will probably have a couple of them done up. I have a nice pair of stag scales that would look great on one, and another pair of mammoth ivory similar to the ones on the Kiwi above. I can't see doing it to a RH one, as I would never carry it, and with the lone exception of my Petoskey Stone one (which I had made for sentimental reasons, knowing full well it is really too soft for knife scales), all my Kiwis get carried. And if he ever decides to do a run of Kopas without clips, I may go broke. :o :DWhyNot wrote:Congratulations! You've got some awesome Kiwis! Would you consider customizing Kopas? I know, you do not like the way they have their clip mounted, but still...
