SS Cricket Jimping
MGK
SS Cricket Jimping
Post by MGK »
Okay, I am ridiculously hooked on the SS Cricket. I have purchased enough of them so that I can start experimenting. I would like to figure out how to put some jimping on it without screwing up the aesthetics of the knife. (That spine can get a little slick.)
I've seen some amazing file work from engravers websites. Anyone tried their hand at this? Results? (Advice is always welcome before I mar up a knife.) :p
mikewww
Post by mikewww »
I believe the grooves should be very fine. Almost as fine as those in the flint wheel of a cigarette lighter. Then they will not mess up the looks of the knife. But how one achieves this I will leave to someone with more skill.
jestyr
Post by jestyr »
dremel is your friend
psimonl
Post by psimonl »
So can the Dremel also be your worst enemy!!! :eek:
Simon
"Everyday above the ground and vertical is a good day".
-Sir A. Hopkins in "The world's Fastest Indian"
"If it hurts, it means you're not dead..."
-Kayakist Marie-Pier Cote
The Spyderco Cookbook
CopilotATS-55
Post by CopilotATS-55 »
psimonl wrote:So can the Dremel also be your worst enemy!!! :eek:
Simon
yes
in a freak shop accident :D
Kyle Decker wasn't here !!! :D :eek:
"Avatar by Dialex
REMEMBER
SFC SHUGART & MSG GORDON
Im still here, just busy being a Senior!!! :D
PNXC
PN
Wrestling
Never Forget 9/11
VMI
10'+3
deeker
Post by deeker »
Save the celebratory drinks for after the task is done! :D
A steady hand will be needed, along with a good clamp or vice to hold the knife.
I'm sure you'll keep us posted on the success of the project?? ;)
MGK
Post by MGK »
Agreed. The dremel is either going to become a close friend or chucked across the garage after the job is done. Will post pics of the impending disaster. ;)
java
Location: Rosamond - Tropical Paradise without the tropics.....(or the paradise)
Post by java »
[quote="MGK"]Agreed. The dremel is either going to become a close friend or chucked across the garage after the job is done. Will post pics of the impending disaster. ]
Chuck it now and avoid the frustration. Fileworking takes a lot of practice and a Dremel is not your friend unless you have a patern jig. Most of us freehand using jewelers round and three-corner files. Knifekits.com sells microfiles and a host of tools for fileworking. But it still takes practice. If you have a good fileworking vice and scrap metal blanks, I would start there. There are good references and video instruction available on the web. Several sites offer tutorials on basic patterns. Here's a couple:
Fileworking a folding Knife
Fileworking Vine Pattern on FB
I work with Art Washburn at his shop occassionally and although his fileworking is excellent, IMO, he is critical and always looking for new tips and patterns......I won't even discuss or show my feeble attempts at fileworking (and I feel like I have a master instructor) At any rate I recommend taking the time to learn fileworking right and practice to make sure you're happy with your handiwork before attacking the Cricket.
Good luck and have fun experimenting! :D
When I said that mercy stood
Within the border of the wood
I meant the lenient beast with claws
And bloody swift dispatching jaws.
Death Before Decaf!
:spyder:
MGK
Post by MGK »
Java- Thanks for the sage advice. I headed over to BladeForums and after a lot of reading I came to the same conclusion as you. Micro files from KnifeKits.com and a lot of scrap metal. Should prove to be a fun little project.
