Strongest Folder
Vincent
Strongest Folder
Post by Vincent »
Which is Spyderco's Strongest Folder?
Som epole say Lil' temp some say ATR and then some say Manix.
speyederlover
Post by speyederlover »
My Manix 80mm seems very strong. So I'm sure a lot of people would say both "Mani" are strong due to blade thickness, the liners and the locking system. A lot of my other Spydies are liner locks. So for the liner locks I would say the blade of the Terzuola Starmate looks very strong as does the Tim Wegner. I don't have a Lil' Temp so I can't really say. Some may say the liner locks are not as strong of a knife because of the liner lock, but the Starmate, Lum Tanto are "tactical" knives in my mind and are strong. Just my thoughts
Military & Lil T
Post by JD Spydo »
To me it is a toss up between the S30V Military and the Lil Temperance. But there are so many Spydercos that are built like a skyscraper that are almost too numerous to mention. My C-44P&S big Dyad is one very tough knife. I have been carrying it for about a year now with no problems what so ever. For a little knife you can't hardly beat the Titanium Salsa ;) :spyder:
Ed Schempp
Compression Locks
Post by Ed Schempp »
I believe that the compression lock is the strongest of the the Spyderco locks The US made back locks are strong, the Chinook and Manix. The Ball lock knives are very strong as well...Ed
boxer93
Post by boxer93 »
I agree on the compression lock. Combine that with steel liners and strong handle material. I'd say Lil Temp or Gunting. Chinook II I believe is a real strong back lock.
Chris
Be Excellent to each other.
STR
Post by STR »
I'd have to give my vote to either the Chinook, or most likely the ATR or the Para Military. Don't discount the nested compression lock knives like the DODO though. They appear to be quite strong also.
STR's Blog
spydutch
Post by spydutch »
I would vote for the Military. Next the Manix...
Crafft
Post by Crafft »
I'd say the Paramilitary.
Vincent
Post by Vincent »
idk about the Military, it only has a 150 lbs/psi rating, at least i think/
psimonl
Post by psimonl »
I would say it is the Chinook II. I recall Mr. Blonde saying that not too long ago that when he was in Spyderheaven, Golden Colorado, they were testing locks in a machine and while the Manix resisted a lot, the machine "jumped" off the floor when the Chinook II lock breaked...
That, my friend, is a strong lock...
Simon
"Everyday above the ground and vertical is a good day".
-Sir A. Hopkins in "The world's Fastest Indian"
"If it hurts, it means you're not dead..."
-Kayakist Marie-Pier Cote
The Spyderco Cookbook
Titus
Post by Titus »
Vincent wrote:idk about the Military, it only has a 150 lbs/psi rating, at least i think/
I would have to agree with Vincent. The liner lock isn't very strong. We seem to be focusing on the locking system, but a knife is "strong" in other areas too. Like blade design, material, and the pivot. I am going to say that the SS ATR is the strongest folder. The steel is stronger than the Golden models. It also has the compression lock and steel handles.
Franco G
Post by Franco G »
Strongest folder - I guess we are talking about the strongest lock.
Military IS NOT. Although a heavy duty, numbers as Vincent said, it does not reach the MBC rating.
Manix and Chinook should be the same - simply, the lock is the SAME.
On general grounds, as Ed said, the compression lock is the strongest. Li' T, Gunting and ATR should be in the same category.
ParaM, being lighter, is a heavy duty, IIRC.
A sprint run, BG-42 Lil' T with integral compression lock (Sal just anounced), would be IMO the strongest one.
Franco
Spyderco: NON MULTA SED MULTUM
My islands
pjrocco
Post by pjrocco »
IMO, the Lil Temp is by far the toughest Spyderco folder..
I'm still praying at night that they do not become FRN Lil' Temps, in the future. :o
Rock
d.g.g
Post by d.g.g »
I'll toss my Rescue into the mix. It gets tons of use by many EMT's/firemen around the world on a daily basis (if that counts for anything). If it weren't tough it would not have this following of folks who use it for work. It has an FRN handle, VG-10 blade, great big spyder hole, and a spyderedge from here to eternity! This puppy cuts!
http://spyderco.com/catalog/details.php?product=72
Simon G
Post by Simon G »
Yup, another vote for the Lil' Temp :D
"From this day to the ending of the world, we in it shall be remembered; we happy few; we band of brothers...for he who today sheds his blood with me shall be my brother." -Henry V
"......and he that has no sword, let him sell his cloak and buy one." - Luke 22:36
Vincent
Post by Vincent »
Im looking for a new folder, cant decode between Lil' temp, ATR and manix,
The Lil' temp is a little small.
Titus
Post by Titus »
What about a Chinook II, Vincent?
Senate
Post by Senate »
I think the LIL'T is the strongest folder of the line, Compression lock is the one! :)
Alexandre.
Chucula
Post by Chucula »
the shorter the blade in comparison with the handle, the more weight the blade could hold (torque). lil temp has the shortest blade, so it makes sense that it can hold the most weight if it's lock is similar to the others.
JohnM
Post by JohnM »
Chucula wrote:the shorter the blade in comparison with the handle, the more weight the blade could hold (torque).
Did you just describe the Yojimbo? :D
