term clarification; what is "the kick"
- Michael Cook
:spyder: I've heard this term thrown around, wazzit mean? :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
Michael,
The "kick" is the unsharpened piece of steel at the base of the knife blade (under the sharp edge, where the 50/50 choil on a Spyderco is) that makes contact with the lockbar when the lockback knife is closed. Its just under the sharpened portion of the blade. Hope this helps.
Cheers,
Sundown
Cheers,
Sundown
GOD BLESS OUR TROOPS!!
- Michael Cook
- Michael Cook
- The Deacon
No, it's the little "nub" at the front of the tang, that dangles down a bit below the sharpened edge. It serves as a "doorstop" to keep the edge from making contact with the spring/lockbar/backstrap/backspacers when the knife is closed. Very pronouced on some designs, like the Military - fairly subtle on others, like the Stretch.Michael Cook wrote: :spyder: So "the kick" is the same thing as the ricasso? :spyder:
There ya have it Michael! I know...not the way you're used to having the word "kick" used, huh? :DThe Deacon wrote:No, it's the little "nub" at the front of the tang, that dangles down a bit below the sharpened edge. It serves as a "doorstop" to keep the edge from making contact with the spring/lockbar/backstrap/backspacers when the knife is closed. Very pronouced on some designs, like the Military - fairly subtle on others, like the Stretch.
God bless :cool:
Proverbs 16:3...Commit YOUR works to the LORD, and YOUR plans WILL succeed!
"Where's the best little big knife not designed by Sal or Eric?" ~ thombrogan, WSM
Avatar by my KnifeBrother, DiAlex...C102 Adventura designer, 2005 Spyderco Forum Knife!
I think the best example of a "kick" is on a balisong.
Its the little piece of steel that protrudes from the base of the blade (looks like they forgot to grind it down), and it is important on a balisong, as it stops the edge of the blade from contacting the inside of the handle, and without it, the blade would become blunt very quickly.
"I Gave You Fair Warning .... Beware" -[infamous]-
[quote="Ted"] ]
You're almost to that day already! I must confess your websites are in my bookmark bar and visited more than once daily. Is that counter at the bottom working? I mean around 40k hits is nice, but I'd think that I am not alone in frequent visits and would be even higher than 40k.
Sorry Michael, I'm not trying to hijack your thread. :o
ASA NISI MASA
- Jim Malone
Real :spyder: collectors are very aware that the kick of the blade will show if the knife has been opened and closed.
The best way to preserve the pristine condition is to put one finger between the blade and the handle when you close the knife.
When the momentum of the blade was stopped by your finger you can use your remaining fingers to slowly lower the blade into the handle.
It's better to be judged by 12 than to be carried by 6
I disagree on the Centofante III letting the blade rest on the handle. It does not. I had one and it did no such thing. It seems like with the Centofante III the spring helps it stay up a little bit. I mean, you can mash it down if you squeeze the thing in your hand but it's not sitting on the handle by itself.
- Michael Cook
Thanks, all!
:spyder: Good answers, good people! :spyder:
Me neither :pSlvgx wrote:Sorry Michael, I'm not trying to hijack your thread. :o
That counter is not really accurate. My provider keeps a stats page also.Slvgx wrote:You're almost to that day already! I must confess your websites are in my bookmark bar and visited more than once daily. Is that counter at the bottom working? I mean around 40k hits is nice, but I'd think that I am not alone in frequent visits and would be even higher than 40k.
Last 12 months show 26,000 visits, 80,000 pages, 50GB of traffic and 3,341,699 hits :eek: (whatever that last figure may mean) The 1997 PDF had 4,326 hits in august and 605 in september so far.
Jim Malone wrote:Real :spyder: collectors are very aware that the kick of the blade will show if the knife has been opened and closed.
Let us have a moment of silence for my lost finger. It was a good finger, however, in my quest to be a real collector, alas, it was lost.........
50GB of traffic!!!! wowwwww, must have cost you a lot of $$$!Ted wrote:Me neither :p
Alexandre.
- Jim Malone
