cleaning sharpmaker
cleaning sharpmaker
Is there any fast and less messy way to clean my sharpmaker stones?
Currently I use a rag and Old Dutch powdered cleaner. it works, but is a pain because I sharpen in my room and have to go down stairs to clean them often.
No short cut
I am afraid I don't have the news you want to hear. But I have found that if I give my 204 Sharpmaker a thorough cleaning it works very well. I first take the stones and soak them in hot dish washing solution ( Dawn). Then I take the stones with a stiff bristle scrub brush and really scrub them with a very coarse/harsh cleanser Like Ajax/Comet. Then I rinse them thoroughly and I take another cleanser called Bar Keeper's Friend and then take a soft bristle toothbrush and scrub them very well. They come out looking like brand new. I am not saying that my way is the only way but I have found that a thorough cleaning does make the unit work very well. However keep in mind: I only find it necessary to do this about once a month
I too want to hear more suggestions. So bring them on :D
- Stuart Ackerman
Lansky make a 600 grit rubber eraser, grey or green in colour, just for cleaning ceramic rods...
My website...
http://ackermancustomknives.com/
Facebook...
https://www.facebook.com/ackermancustomknives/
Facebook...
Comet on a wet sponge.
You might want to consider moving your sharpening operation to the kitchen. I recall reading on one of the forums that the Sharpmaker was designed to be used at the height of the average kitchen counter. Having tried it on various tables I agree the kitchen counter is an ideal height, and it provides instant access for cleaning the rods.
Everything in moderation, including moderation.
- greencobra
Steel wool pads work better than plastic-type pads like Scotchbrite. I know that doesn't make sense, it seems like the steel wool should get "sharpened" and re-clog the stones. But, as long as the steel wool is charged with detergent -- ala SOS pads -- it's the fastest way to clean the stones that I've found.
- Stuart Ackerman
I was sharpening a lot of M2 and D2 blades at one time, and the rod seemed to get slicker... I blasted the rod with kiln dried beach sand, very fine, and it made it as good as new.greencobra wrote:I'm sorry, I didn't read the whole thread but is there a point that one would get to where the stones would be ruined? Is too much cleaning as bad as not cleaning?
I suggest that you are very careful if you decide to do this, and if you break the rod, I will not be held responsible :)
My website...
Facebook...
Facebook...
thats what I use for the daily scrubbing.Joe Talmadge wrote:Steel wool pads work better than plastic-type pads like Scotchbrite. I know that doesn't make sense, it seems like the steel wool should get "sharpened" and re-clog the stones. But, as long as the steel wool is charged with detergent -- ala SOS pads -- it's the fastest way to clean the stones that I've found.
