Hey all,
Got a question, will aTuf Cloth or Tuf Glide do any damage to FRN or G-10 handled Spydercos, or to the washers if applicable?
How Bout Them Red Sox!!!!!!!!
Rob
Tuf Cloth and Tuf Glide use
HOW BOUT THEM RED SOX!!
ODIN, GUIDE MY SWORD TO ETERNAL VICTORY!
Aloha wotanson!
I don't see a need for Tuf Cloth on FRN or G10...but I have used it on some of my G10 "keepers" which I no longer have! LOL! It wasn't affected in the least...My Tuf Cloth Marine grade keeps my Mossberg 590A in top shape!
As for the Tuf-Glide, I don't THINK it'd harm washers, but I still don't trust the stuff on O-rings yet...
Anyways, do you recall the name of that knife shop in CT ya visited?
God bless!
God bless!
Proverbs 16:3...Commit YOUR works to the LORD, and YOUR plans WILL succeed!
"Where's the best little big knife not designed by Sal or Eric?" ~ thombrogan, WSM
Avatar by my KnifeBrother, DiAlex...C102 Adventura designer, 2005 Spyderco Forum Knife!
Thanks Daywalker,
I don't actually use it on the scales, but when I use the cloth on the blade some does get on the scales, just concerned with a chemical reaction to the handle material. The Tuf Glide I use on the pivots and moving parts, again just concerned with same. thanks for advice and I sent you a PM.
HOW BOUT THEM SOX
Rob
HOW BOUT THEM SOX
Rob
Sentry Solutions
I am very impressed with the whole line of knife care products from the folks at Sentry Solutions ( The makers of Tuf Cloth & Tuf Glide). There is another company that has maintenance/care type products for you knife and other essential hardware and that is the Flitz company. I particularly like the Flitz polishing cloth for all my stainless blades and so forth. Their metal polish is number 1 in my book. If any one knows of anything else that could rival either one of these great companies I would appreciate knowing. JD Spydo :)
Tuf Glide did not do a great job protecting my 440Vs from rust but I have had no problems at all sence I switched to MiliTec-1.
I did do a small test when I had some of the Tuf glide.
I put it on one side of a pair of pliers and Militec-1 on the other side and placed out side.Rust was formimg badly on the Tuf glide side after one day.The militec-1 side went 4 days and through some rain before rust started showing up.
[CENTER]0 0[/CENTER]
[CENTER]<[/CENTER]
[CENTER]\____/[/CENTER]
[CENTER]<[/CENTER]
Flitz metal Wax
Hello there J Smith. That means a lot when you actually put these products through an unbiased test. I have tested the Flitz metal wax with a similar test like you described and had really good results. I will admit however that I did put on a thick amount of it. On problem with the Tuf-Cloth is that it tends to lose the chemical the cloth is treated with pretty quickly. I do really like the Militec products. They sent me a sample of their grease and it is some super stuff. :spyder: :)J Smith wrote:Tuf Glide did not do a great job protecting my 440Vs from rust but I have had no problems at all sence I switched to MiliTec-1.
