Dealing with pivot play when there is no screw
Nemo
Post by Nemo »
Hi,
on stainless steel handle and many FRN handle there is no screw to deal with any lateral or vertical play in the pivot area.
how do you deal with that yourself ?
Is it getting worse with time or is it stabilizing?
Any cure ?
cheers
JM
Ted
Post by Ted »
I've heard that a hammer could fix that. I guess (have never done it) you could clamp the pivot area between two pieces of wood (1/4" think or so?) and give a gentle tap with a hammer on one side and see how it works out.
Ted
chux
Post by chux »
What Ted suggested works fine. I have tightened an FRN Delica with this method with no problems. Not sure how easy it will be with SS versions, the FRN is more predictable because of the ball capped rivets.
Blades
Post by Blades »
You can also squeeze it very gently in a vise. Check it, then squeeze it some more if it needs it.
Blades
Nemo
Post by Nemo »
Thank you for your "ad vise" !!
I will keep that in mind !
cheers
JM
