Spyderco Native Chief Lightweight Observations
- cabfrank
Re: Spyderco Native Chief Lightweight Observations
I've heard of LW Salts that are typically Syderco, and issue free, and I haven't heard of issues with the G10 models. It could just be a production run or bad luck. I would still recommend the model, but check it when you get it, and wait for a good example.
my g10 ones were solid functionally. I've bought 10 over the years. Rex 45, 4V, M4, M4 DLC, S30V etc. Multiples of many.cabfrank wrote: ↑Mon Jan 20, 2025 6:38 pmI've heard of LW Salts that are typically Syderco, and issue free, and I haven't heard of issues with the G10 models. It could just be a production run or bad luck. I would still recommend the model, but check it when you get it, and wait for a good example.
Only issues I had with the G10's from a fit & finish aspect is backspacers were never flush on the DLC models.
viewtopic.php?t=89912vivi wrote: ↑Mon Jun 07, 2021 1:13 pmM4 Native Chiefs are arriving today.
This thread is for reporting on fit and finish, sharpness, how they work for you after carrying them etc.
I got multiples today and immediately stuck one in my pocket.
Sharpness is excellent. Entire edge is evenly ground and hair popping sharp.
Pivot is smooth but stiffer than my Rex45's, which is typical when comparing DLC vs satin of the same model.
Fit and finish on this one seems perfect except for one little flaw. The scales are a bit proud of the backspacer. Small enough of a difference I didn't notice when I visually inspected it, but enough I feel it when I reach in my pocket.
I plan to take the scales off to contour and dye them, so I can fix that at the same time.
The G10 feels a touch grippier than my rex45 did when new. I like it.
Really enthusiastic about this combo. I already loved the Chief and I love M4. The DLC blade & hardware with no liners should prove very corrosion resistant for an M4 folder. This will see a ton of carry.
I think I mention it in my 4V thread too but didn't read through it viewtopic.php?t=91597
