Show your Mule
DM11
#421
Post by DM11 »
MT12 came today. :)
MT12 039.JPG (83.06 KiB) Viewed 5009 times
Hold Fast
David
DCDesigns
Post by DCDesigns »
jtoler_9 wrote:Finishing my first ever mule. MT11 Used Ironwood for the scales. I'm happy with it for a fist ever attempt. Still just a few more adjustments to go before finished.
That looks great man! well done!
GLOCKCRAZZ
Post by GLOCKCRAZZ »
MT7 & MT11
GLOCKCRAZZ
MT11
DougB2
#425
Post by DougB2 »
phillipsted,
I like how your micarta turned out! What size screws did you use?
phillipsted
#426
Post by phillipsted »
DougB2 wrote:phillipsted,
Thanks, Doug! I use the F6 Stainless Pivot Pins from Jantz (http://www.knifemaking.com/product-p/f6.htm). These use a 4-40 button head Torx bolt and a 0.1875" x 0.500" threaded spacer. The Torx bolts have a 0.210" head, so if you step-drill your holes in the scale material, the bolt heads will cinch down scales onto the blade. This is the same type of attachment that Halpern provides with its scales.
This set of micarta scales is not glued at all - the bolts, pins and friction hold the scales onto the knife. Since this is going to be primarily a display piece, this is OK - I might even go back and add a contrasting red spacer at some point. But all my user Mules get the Epoxy - especially the non-stainless ones where corrosion under the scales can be a problem...
TedP
phillipsted
Problem with artisan Micarta
#427
I finished another set of scales for my Woodcraft Mules today. For this one, I had high hopes for some "artisan" micarta made by someone on eBay. This was his maroon-and-dark-brown linen micarta. This isn't truly micarta (which is actually a registered trade name) - because it uses what appears to be a commercial-grade epoxy rather than a phenolic base. Overall, I like the color scheme and workability of the material.
The problem with the material starts to manifest itself once I had the scales shaped and began to sand it down. For this life of me, I can't get it sanded smooth - the pits and divots in the material simply don't sand out. Then it dawns on me - these are voids in the epoxy substrate that were created during the backyard manufacturing process. No matter how much I sand, they aren't coming out. So I just sanded it down to 1200 grit and buffed it with green compound on a felt wheel. You can see the result.
Fortunately, when I saw what was going on, I didn't glue the scales to the blade, so I can put another set on later.
Anyone have thoughts about anything I might be able to treat the scales with to fill some of the voids?
TedP
jabba359
Post by jabba359 »
phillipsted wrote:Anyone have thoughts about anything I might be able to treat the scales with to fill some of the voids?
TedP
I see people use superglue to fill in small holes in wood. They take some of the wood dust from sanding, mix with superglue, and fill the holes. Once dry, it can be sanded smooth. I imagine it would work just as well for micarta, but I haven't worked with micarta before. Perhaps someone with more experience with this material can substantiate or invalidate my suggestion.
-Kyle
:bug-red
http://www.spydiewiki.com
SQSAR
#429
Post by SQSAR »
You are correct, , ,the same techniques works well with Micarta. What I've done before is just put a drop on the gap/hole/imperfection/void that needs to be filled, than then sand right over it. In just a couple of seconds you are good to go.
phillipsted
#430
Good suggestions, folks. I've used the Superglue trick before, but to fill larger divots. This set of scales will require me to coat virtually the entire handle with a thin film of glue, then sand it down. Not sure how that would turn out.
I'm also toying with the idea of using a gun stock finish called TruOil. It is a catalyzed linseed oil product that finishes to a hard durable gloss which can be sanded.
Sorry to get off topic from the "Show Your Mule" thread. I'll post more pictures of the doctored scales when I'm done...
TedP
TheNeedyCat
#431
Post by TheNeedyCat »
i dont have one :( i want one but everyones so far look great
Freediver
#432
Post by Freediver »
Is there anyone that sells CF mule scales? I was just checking out the Halpern site and was bummed to see they don't.
Donut
#433
Post by Donut »
Maybe email them and ask if they do.
-Brian
A distinguished lurker.
Freediver
#434
Post by Freediver »
Alright, just did. :) I also just ordered a M390 mule a few minutes ago.
SQSAR
#435
Post by SQSAR »
phillipsted wrote:Good suggestions, folks. I've used the Superglue trick before, but to fill larger divots. This set of scales will require me to coat virtually the entire handle with a thin film of glue, then sand it down. Not sure how that would turn out.
TedP
Good idea on the TruOil, it will work nicely. When using CA glue (superglue) to cover larger areas like you described, just do patches at a time by spreading the CA around with a Q-tip (you will have to work fast) and you should have no troubles.
Mr-No
#436
Post by Mr-No »
my Name is Norbert from Germany and this is my first Mule ,
I hope it like to you
bartvdb
#437
Post by bartvdb »
mr no ; nice blade **** of a first post! welcome and greeetzzz .
Senate
#438
Post by Senate »
that's pretty awesome... what wood did you use?
Alexandre.
Mr-No
#439
Post by Mr-No »
sorry , i have forget , the Wood is Stabilized Burl
DCDesigns
Post by DCDesigns »
Senate wrote:that's pretty awesome... what wood did you use?
Looks like spalted maple burl.
