Concealex for the H1 Warrior
HotSoup
#41
Post by HotSoup »
Mike,
I have a couple questions, as I've already expressed interest in the Warrior and a custom sheath before with you.
-Do you make them in CF pattern Concealex?
-H-1 is a pretty soft steel, and scratches extremely easily. Do Concealex sheaths scratch the blade after repeated draws and sheathing even if its clean?
Hawke
#42
Post by Hawke »
Hey Mike, thanks for the response. I sent you a PM.
Mike Sastre
Post by Mike Sastre »
HotSoup wrote:Mike,
HotSoup,
I will make the H1 Warrior sheath in Carbon Fiber pattern or Coyote Brown on special request, but only do those as ordered - not a stock item. Both materials cost me a lot more than black or olive drab, so are a little more expensive. Just checked the knife I use for checking the fit and tension of the sheaths (100s of draws at speed), and there are only a couple of very minor rub marks on the blade, that you have to look closely to see. I intentionally build in some "freeplay" around the blade to minimize these. It is dirt and debris on the inside of thermoplastic sheaths that causes scratches. Rub marks come from sheaths that are too tight around the blade, or off-axis draws and re-sheathing.
HotSoup
#44
Post by HotSoup »
Thanks for the information.
Going to keep it all in mind for the future.
Mushinto
#45
Post by Mushinto »
Mike Sastre wrote:I've got a long history with sheaths for the Warrior series of knives and have had a few people asking for them. Pretty busy right now, but managed to sneak in a prototype with the other sheaths I was doing today. Should have some of these available soon. Features Spyderco's G-clip.
Are they available now? I want one.
ML
Dr. Snubnose
#46
Post by Dr. Snubnose »
Nice work as always Mike....If I had plans to buy a warrior, you'd be the man making my sheath....I see Sal even wants one...we are slowly and surely turning Sal into a FB fanatic.....LOL.....Maybe.....Doc :D
Maako
#47
Post by Maako »
Nice work!
I'm left handed, so Spyderco got a special place in my heart =)
I'm I right in thinking that the clip can be fastened on either side?
Or do I need to get a customized lefty made?
Mike Sastre
The Spyderco G-clip allows you to place it on either side of the sheath at various angles. Screw and post attachment - sheath body and G-clip are separate. You can also attach an optional IWB loop to replace the G-clip.
wquiles
#49
Post by wquiles »
fims wrote:its looks factory issue. Nice job.
+1
Mike Sastre
I like to think better than factory - it's a custom sheath after all. :) I've been doing this for over 20 years.
freewheeling
#51
Post by freewheeling »
Mike Sastre wrote:I like to think better than factory - it's a custom sheath after all. :) I've been doing this for over 20 years.
How do you order one?
Stuart Ackerman
Post by Stuart Ackerman »
freewheeling wrote:How do you order one?
Look in the post before yours...he has a link under his name...
like this...
http://www.RiverCitySheaths.com
