Concealex for the H1 Warrior
Mike,
I have a couple questions, as I've already expressed interest in the Warrior and a custom sheath before with you.
-Do you make them in CF pattern Concealex?
-H-1 is a pretty soft steel, and scratches extremely easily. Do Concealex sheaths scratch the blade after repeated draws and sheathing even if its clean?
- Mike Sastre
HotSoup,HotSoup wrote:Mike,
I will make the H1 Warrior sheath in Carbon Fiber pattern or Coyote Brown on special request, but only do those as ordered - not a stock item. Both materials cost me a lot more than black or olive drab, so are a little more expensive. Just checked the knife I use for checking the fit and tension of the sheaths (100s of draws at speed), and there are only a couple of very minor rub marks on the blade, that you have to look closely to see. I intentionally build in some "freeplay" around the blade to minimize these. It is dirt and debris on the inside of thermoplastic sheaths that causes scratches. Rub marks come from sheaths that are too tight around the blade, or off-axis draws and re-sheathing.
Mike
http://www.RiverCitySheaths.com
"Kitchen Kydex" DVD sets available. http://rivercitysheaths.com/dvd.html
Are they available now? I want one.Mike Sastre wrote:I've got a long history with sheaths for the Warrior series of knives and have had a few people asking for them. Pretty busy right now, but managed to sneak in a prototype with the other sheaths I was doing today. Should have some of these available soon. Features Spyderco's G-clip.
ML
- Dr. Snubnose
Nice work as always Mike....If I had plans to buy a warrior, you'd be the man making my sheath....I see Sal even wants one...we are slowly and surely turning Sal into a FB fanatic.....LOL.....Maybe.....Doc :D
- Mike Sastre
The Spyderco G-clip allows you to place it on either side of the sheath at various angles. Screw and post attachment - sheath body and G-clip are separate. You can also attach an optional IWB loop to replace the G-clip.
Mike
- Mike Sastre
I like to think better than factory - it's a custom sheath after all. :) I've been doing this for over 20 years.
Mike
- Stuart Ackerman
Look in the post before yours...he has a link under his name...freewheeling wrote:How do you order one?
like this...
My website...
http://ackermancustomknives.com/
Facebook...
https://www.facebook.com/ackermancustomknives/
Facebook...
