H1Spyderco Machete?
Stuart Ackerman
Re: H1Spyderco Machete?
#361
Post by Stuart Ackerman »
… and sent. Four emails with one image each.
Stuart Ackerman
#362
Ooops. Another email with me holding the handle for scale
Fireman
#363
Post by Fireman »
There was some talk about the Silky handles on a thread where we were talking about this topic but not sure which thread. I went by an REI and found a Silky Ono and it has that removable rubber handle. I was impressed and picked it up for some personal testing and fun. The handle feel and size make it a comfortable grip. I hope there could be a Silky/Spyderco collaboration with this handle.
Mule Team Army 001 (patched)
MNOSD 008 :usflag
Stuart Ackerman
#364
I have never contemplated serrations on curved blade machetes and kukhris. I use my kukhris the traditional way, with the handle pivoting on the thumb and finger joints, to accelerate the blade strike. Hard to explain, but there are videos in YouTube showing you how. For me that would mean the serrations would work like rapid push strokes, not sliced as per katana strikes. I might do a Spook with serrations to see how it might work with my methods. The Spook is smaller than most machetes, but I wanted an easy edc in the wilds. And this steel type could be touched up with a random abrasive rock or pebble .
Bill1170
#365
Post by Bill1170 »
It’s an interesting question whether serrations will help or hinder the effectiveness of a chop or push cut. A push cut with serrations isn’t a pure push cut by every part of the edge. The points and the center of the scallops are doing a push cut but the rest of the edge is angled to the direction of the cut, resulting in a shearing action. My experience with woodworking is that a shearing cut has advantages over a straight push cut.
For one, the effective bevel angle of the edge becomes lower than the actual bevel angle measured perpendicular to the edge. This is why woodworkers will skew a plane or chisel when cutting particularly difficult wood. It’s also why a guillotine has an angled blade; it’s more effective for trimming miters or French royalty.
#366
Stuart Ackerman wrote:
Fri Oct 24, 2025 2:16 pm
Hi Stuart,
I did not receive any of your emails?
Stuart Ackerman
#367
Hi Sal. Apologies. Sent again in one email five images
Fireman
#368
Post by Fireman »
Bill1170 wrote:
Sat Oct 25, 2025 8:02 pm
Good points with morbid historical humor. This makes me think if a “Kris” blade edge “serrations” might be the Goldilocks serrations pattern for a machete. This could be done without a primary grind kind of like a wavy scandi with about a .5” or 1cm from apex to apex. So you could potentially sharpen this in the field with a round abrasive stone or file by dragging it parallel to the edge back and forth. This would add some extra length to the edge and different attack angles as you swing it.
MNOSD 008 :usflag
#369
I know the two smaller SE profiles I tried, they would drag cut though things just fine, but they did chop or hack at the vines and limbs well at all guys.
This last profile I have does much better at either and yet the PE Kukri does a much better job at chopping and hacking.
Now, with the angle the Kukri does prompt the cutting process at a chopping and/or hacking does set up somewhat of a cutting than a straight edge does. I like the Kukri design for this reason really well, if I am making any sense here. Hard to type what I am trying to explain lol.
Stuart Ackerman
#370
Hi Sal. Please check your aol email now? Hopefully you can see the Spook at last? 😳
#371
Hi Stuart,
yes, I received the pictures. Thanx.
Stuart Ackerman
#372
Regardless of how you feel about the Spook, Sal, I will send you a bare steel and Pakkawood scaled Spook. Non knife folk love how it swishes as an extension to your hand.
Fireman
#373
Post by Fireman »
Here is a Shun bread knife that has kind of what I was saying about a wavy edge. I think maybe 5/8” apex to apex might be good size for a serrated machete. Easy to field sharpen with a rod abrasive
MNOSD 008 :usflag
