Post up your Rit dye projects..
- RadioactiveSpyder
Re: Post up your Rit dye projects..
Thanks Ranger and Capt’n, I’m very pleased with how this one turned out - possibly my best RIT dye job to date. I also made a very nice-looking gray one too but sold it on BF a while back. I’ve found foliage green G10 is very accepting of the actual RIT dye color/shade you’re shooting for. Cheers, Radioactive
what?! gray plus yellow equals green?!40mm wrote: ↑Fri Feb 18, 2022 7:24 pmHey! I used gray Rit Dye, the powdered kind, and literally dipped it in there for 5 seconds at a time. I knew it would go quick so I would dunk in the dye, pull, rinse in cold water, and repeat.
Untitled by Six Pound Cat, on Flickr
thanks for sharing!
- Knives&Lint
I've done it a few times to the Salt yellow. First I use the "Kelly Green" powder towards the pivot end to give it a lime green look. Then I finished with a fade using the "Aquamarine" liquid
Pictured here with a non-Spyderco that started as "Jade" (not translucent) with a "Royal Purple"/"Tropical Teal"/"Emerald" fade.
Most recently I hit the K390 blue Stretch with a synthetic liquid "Sapphire Blue" fade
That is a very impressive fade job. Well done.
- Knives&Lint
Thanks brother! Every time I'm scared to death I'm going to ruin it, but so far it has always turned out well.
- Ranger_Ike
These look great! What did you do to the stretch blade? Is that a custom patina?Knives&Lint wrote: ↑Sun Feb 27, 2022 6:21 pmI've done it a few times to the Salt yellow. First I use the "Kelly Green" powder towards the pivot end to give it a lime green look. Then I finished with a fade using the "Aquamarine" liquid
- Knives&Lint
Many thanks! Yea, I was experimenting a bit with this one because this is something I've only ever done before on traditionals with carbon steel blades. First, I soaked the blade in some apple cider vinegar for about a half an hour to get a nice even base patina going. Then for the design I used mustard with a little apple cider vinegar mixed in to get the consistency right, and then apply it with a toothpick. I applied a couple of lines following the lines of the edge, and then applied the dots to the rest of the blade randomly. Then let it sit for 30 min, rinse it off, and reapply. For the second coat I just did one line in between the earlier two, and then again randomly applied the dots to the rest of the blade. It's where the two coats overlap that you really get the blues to come through at certain angles. I'm really happy with how it turned out even though it's not exactly how I had envisioned. I'm diggin' the Stretch quite a bit and glad I picked it up.Ranger_Ike wrote: ↑Sun Feb 27, 2022 8:19 pmThese look great! What did you do to the stretch blade? Is that a custom patina?
Here's a closer view of the other side
There's some pretty good tutorials on YouTube, including one where a guy does it on an Opinel, which is the method I follow for the mustard design. Here's something I was able to achieve on a GEC and a Case, where I just used the mustard and didn't do the ACV soak. I now do this on all of my GEC's and Case's with CV steel, I let the main blade get a natural fruit patina and then do a design on the secondary blade. With the Stretch I was experimenting with combining the two methods.
- Ranger_Ike
Knives&Lint,
That’s some great work. Kind of reminds me of fish scales. I might have to give that a try on some of my case carbon blades to test it out. Thanks for sharing.
I'm wondering if anyone has dyed the K390 FRN scales a darker shade of green or really what the color options are (other than black) if you start with this:
Those fades look great. That K390 Stretch 2 looks amazing! I would love to see Spyderco do fades like that with their “Zome” process.Knives&Lint wrote: ↑Sun Feb 27, 2022 6:21 pmI've done it a few times to the Salt yellow. First I use the "Kelly Green" powder towards the pivot end to give it a lime green look. Then I finished with a fade using the "Aquamarine" liquid
https://i.imgur.com/1dRvZIc.jpg
https://i.imgur.com/kYIUK9N.jpg
https://i.imgur.com/wayhwX6.jpg
Knives&Lint got some impressive results on their K390 Stretch 2!
- Manixguy@1994
All of these pictures are amazing. I’ve put it on my to do list once the weather breaks . First challenge will be what folder will be my first Guinea Pig .
Mendozamike89
What green did you use on the mint green to get this color
51 spyderco knives in 20 different types of steels.
My Top 3 EDC
-1- Smock s30v with black RGT micarta and lynch clip. With Skipp 3/16"1/16"11 ball bearings.
-2- Sage 5 lw (bladehq exclusive) with black m4 steel rit dyed dark green & black lynch clip to match
-3- Shaman with cruwear dlc (knife joker exclusive) with gray micarta RGT scales and long gray lynch clip.
Pacific Salt LC200N in a 30 minute Royal Blue bath. Sorry for the photo dump. It is really hard to get the true color in pictures. So I tried with different locations and lighting. I would say in real life it is more to the green side than the blue side. I tried a 15 minute bath, but it was just green still.
jsumm, that looks like the "real teal" doc dan was looking for.
Yeah it seems a little more on the green side especially in person. I think it is close to what he was describing.
- Manixguy@1994
Looks awesome Jeff . Dan
Last edited by Manixguy@1994 on Wed Apr 13, 2022 12:16 am, edited 1 time in total.
Thanks Dan! A little better for an EDC in khakis.
@Mendozamike89 I used peacock green. Didn't take very long. -Chad
Mendozamike89
I used peacock green on the mint green blade HQ exclusive m4 sage 5 and got this color after about 20 mins on broil with just a dab of dawn soap and water with rit dye synthetic dye more
[/img]
[/img]
My Top 3 EDC
- przemekspce
I haven't seen this post before, these knives look great! UKPK got Kelly Green.Knives&Lint wrote: ↑Sun Feb 27, 2022 6:21 pmI've done it a few times to the Salt yellow. First I use the "Kelly Green" powder towards the pivot end to give it a lime green look. Then I finished with a fade using the "Aquamarine" liquid
