KnifeCenter Exclusive CPM-Cruwear Paramilitary 2
rivy
Re: KnifeCenter Exclusive CPM-Cruwear Paramilitary 2
#241
Post by rivy »
knivesandbooks wrote:
Sat Sep 15, 2018 12:13 am
I'm surprised these are still around too. Been loving mine. Half expecting knifecenter to order these in pakkawood.
Well that would be awesome. I'd be in for one for sure.
ferider
#242
Post by ferider »
KC just put a CPM CW PM2 for me in the mail ... still in stock, get them while you can.
#243
If pakkawood made it over to Golden that would be awesome. K390? :D
skybladefromthe
#244
Post by skybladefromthe »
I think KC sold out. I can't find them on their site anymore. Says discontinued. Got mine a few weeks ago. I had to work on it though. It had months to break in lock stick. I did a bit work on the lock bar and I smoothed some of the edges of the "smooth" scales. It's a serious snap to deploy. No more stick either. The blade's grind is amazing! Recently I bought some blurple scales so I think I'll swap for a while. Yes for sure I would way more want a grey but I am a liker of blurple.
https://www.knifecenter.com/item/SP81GP ... -exclusive
BIGSTRETCH
#245
Post by BIGSTRETCH »
I was really happy to get in on this after missing out on all the Cruwear sprints last year. Has anyone tried sanding the scales to a coarser, rather than smoother finish?
rgrad80
#246
Post by rgrad80 »
BIGSTRETCH wrote:
Tue Sep 18, 2018 9:26 pm
I’ve seen a few examples on the scales sanded down and they look great. Search for smooth cf scales and will come up.
Days without buying a Spyderco: 35
You always have a choice.
BIGSTRETCH
#247
rgrad80 wrote:
Tue Sep 18, 2018 9:35 pm
Has anyone tried to rough up the finish to create a more coarse texture though?
Joey
#248
Post by Joey »
That would be very interesting to make it coarse. I really like the smooth finish, personally. It’s a very welcomed feel in comparison to all of the textured G10 and FRN/FRCP most knives come with. I especially like how I don’t have to worry about losing the new knife feel. It gets far more carry time than my other knives for that reason.
Pelagic
#249
Post by Pelagic »
I'd be more interested in a coarser finish as well, possibly similar to what 40 grit sandpaper would do. I'm almost tempted to try it.... 2 directions, perpendicular, essentially making an "X" on each scale, and then very lightly hitting it with 2000-3000 grit to take the bite off any existing g10 spikes.
I bought normal spyderco g10 scales for my cruwear pm2, but I still own the smooth g10 scales which are mated to an m4 blade.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
BIGSTRETCH
#250
Pelagic wrote:
Wed Sep 19, 2018 3:05 am
I'd love to see how that turns out if you decide to try it! From checking out some other threads, it sounds like it is a good idea to do it outdoors and with a respirator or else under running water.
ejames13
#251
Post by ejames13 »
BIGSTRETCH wrote:
Wed Sep 19, 2018 5:54 am
I've had this in the back of my mind since I bought mine. I'm just too afraid to try it for fear of wrecking the scales! I'd be curious to know how it turns out if you try it though :D
blues
#252
Post by blues »
I guess you could always put some adhesive backed skateboard tape on them. (Just kidding...)
I don't have the guts to mess mine up so I'll probably leave them as they are unless a foolproof method is offered.
- Retired from the chase -
ejames13
#253
Post by ejames13 »
Has anyone noticed the difference in the way the plunge line is ground between this run and the grey G10? Here's a comparison shot. Smooth G10 model is mine. Grey G10 pic borrowed from forum member Tabo.
I really like the change. It feels smoother on the thumb when opening, and I think it looks better.
ejames13
#254
Post by ejames13 »
Double tap.
attila
#255
Post by attila »
I haven't had an older plunge style, but, to me at least, it is more aesthetically pleasing than the newer plunge style.
Want: SPY27, K490, Swick 5
#256
Interesting. I have had a few PM2s were that edge on the hole was uncomfortably sharp. I hadn't noticed this, but looking back it is a pretty noticeable change on all the new ones.
#257
ejames13 wrote:
Wed Sep 19, 2018 8:12 am
Yes, the change in the plunge grind has been mentioned a couple times. I don't know for sure but it seemed like they made the change right after the Grey Cruwear sprint run. Personally, I think the angled plunge grind looks nicer. I can't say I've ever noticed a difference in feel between the old and new. I'll have to check it out later when I get home.
Pelagic
#258
Post by Pelagic »
I think the gray scales that came on the older cruwear models (as well as the gray that came on the Maxamet models) are perfect. Gray just comes off as a hard use color to me, which suits the capabilities of cruwear.
I love the gray, the red (m390 sprint) and bright blue (also m390 sprint) quite a bit. Not a big fan of the smooth g10.
VA.koi guy
#259
Post by VA.koi guy »
New plunge line=CQI
love that Cruwear!
Need more. (Hint hint)
anycal
#260
Post by anycal »
Same with the PM2 M390 releases. BBS had the old line, DLT was like the new one.
Peter
