Easiest Sharpening Spyderco Steel
RustyIron
Re: Easiest Sharpening Spyderco Steel
Post by RustyIron »
horzuff wrote:
Fri Apr 11, 2025 4:07 am
What I mean is sharpening high hardness and wear resistant steels isn't necessarily hard, but rather tedious. You just have to go at it for a long time
I don't find that to be the case, either. I like the angles that Spyderco provides from the factory, so on a new knife, it might take five to ten minutes to get the angle I want. I recently got a Microtech in M390MK. The angle wasn't anywhere near what I like. I wasn't timing myself, but I can't imagine it took more than 10 or 15 minutes. To me, that's not slow and tedious. I'm happy with that. For finish work, I use diamond matrix stones. For hogging off a lot of material, I use some cheap diamond plates.
Where you might be getting the impression that working with fancy steels is tedious is from the folks who are reprofiling their knives using ceramic stones on a SharpMaker. The Sharpmaker is GREAT when using it for its intended purpose. It's not so great when used for purposes for which it was not intended. When I read about people who watch the entire Godfather trilogy while sharpening a knife, I wonder if they might benefit by using different tools. But if that's what they want to do, good for them. Everyone has their own way. It took Hatori Hanzo a month to make a sword for Beatrix Kiddo. I don't have that kind of patience. Nor am I looking to cut God if I should run across him in my travels.
8th_Note wrote:
Fri Apr 11, 2025 7:37 am
My favorite to sharpen are the sprints in Micro-Melt PD#1. It's easy to get a beautiful and razor sharp edge.
My hardest Spyderco to sharpen is my Tasman 1 in H1. But thats because it's a hawkbill and I don't have any rods, only diamond stones and a paddle strop.
sheet of sandpaper wrapped around anything with a hard edge will make touching up the tasman very easy. I used to do that with a piece of leftover grip tape with my SE tasman.
8th_Note
Post by 8th_Note »
Fri Apr 11, 2025 8:02 am
Thanks for the tip
Chieftjs
Post by Chieftjs »
Great Information folks, Thank you! I guess to clarify a bit I was a little tongue in cheek wanting the steel that I’d have to sharpen the most because I’m enjoying using my sharpmaker so much. I have a VG10 Delica and a couple VG10 Endelas as well. The Para3 just seems to be my Excalibur at the moment.
-Tim-
Pacu0420
Post by Pacu0420 »
For me, it's Spy27. It also hold an edge quite well. S90v is pretty easy too. Of course, I'm using a fixed angle sharpener with diamond stones. So "easy" isn't really the right metric. It's more about how long it takes. Especially when reprofiling.
cjk
Post by cjk »
Chieftjs wrote:
Thu Apr 10, 2025 8:23 pm
I got a Sharpmaker recently and have been obviously sharpening everything in sight so what Para3 can I buy that I’ll need to sharpen a lot (lol).
The Para 3 lightweight in BD1N.
JMM
Post by JMM »
Easiest to sharpen: 8cr, bd1, 52100
Can get sharpest: vg10, superblue, xhp
Deadboxhero
Post by Deadboxhero »
Learn to sharpen, fear no steel.
Big Brown Bear
Triple B Handmade Knives
Chieftjs
Post by Chieftjs »
Deadboxhero wrote:
Fri Apr 11, 2025 8:09 pm
Best excuse I’ve heard to order the Maxamet!
-Tim-
KeepCalm&Carrion
Post by KeepCalm&Carrion »
I've only sharpened PE VG-10 thus far, and I gotta say I was shocked at how easily and quickly I could bring that blade back to an impressively sharp edge.
Perched on a Blue Ridge
Eyes toward the Pacific
Redwoods set me free
Coastal
Post by Coastal »
I don't know which is the easiest, but the ones I enjoy sharpening the most are 52100, H1 and K390.
Fireman
#32
Post by Fireman »
Part of the equation should be how many times you can strop the knife to a good edge before needing to sharpen again. Also the edge angel plays a big part.
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
Enactive
#33
Post by Enactive »
Fireman wrote:
Sat Apr 12, 2025 12:24 pm
The edge is a ghost, not an angel! :zany
cabfrank
#34
Post by cabfrank »
Not both?
Chieftjs
#35
Post by Chieftjs »
Great name for a new knife. The Ghost Angel!
-Tim-
#36
LC200N for me
Nestor
#37
Post by Nestor »
H1/H2
horzuff
#38
Post by horzuff »
RustyIron wrote:
Fri Apr 11, 2025 8:00 am
I don't understand what You are trying to argue here. I did write using diamond abrasives nullifies the issue pretty much, though not completely. You still need to spend more time on the stone, whatever grit progression You choose, when forming an edge on a high edge retention steel vs a more simple alloy.
What does angle have to do with anything when we're comparing steels not geometry?
I'm not getting my impressions from anywhere else but the hundreds or thousands knife sharpenings I did over the years with pretty much every sharpening method and abrasive there is. And I still say that supersteels take longer than simpler steels.
Or do You mean to claim that there is no difference between sharpening/reprofiling a knife made of, let's say AEBL vs something like REX121? Because that's just not true factually.
RustyIron
#39
Post by RustyIron »
horzuff wrote:
Mon Apr 14, 2025 6:40 am
I wasn't trying to argue.
My goal was just to clarify the answer to the question.
Maybe others can an be more clear.
apollo
#40
Post by apollo »
Enactive wrote:
Sat Apr 12, 2025 1:14 pm
I know Sal says that. But in my experience an edge can indeed be an angel or even a devil when it comes to sharpening... :zany
