Z-Cut breakage
Re: Z-Cut breakage
Doc Dan wrote:
Fri May 28, 2021 11:01 pm
I use my Z-Cuts every single day, literally. I never take special care of them. I wash them by hand and let them air dry. I have no rust whatsoever, and so far no issues with breaking...and I would think if they were going to break they would have, given as much use as they get.
Same. I keep one at home and use it most times I cook, and keep another in my knife roll at work. Both have held their edge quite well. I've experienced no corrosion. Mine will flex in denser foods but I've never seen any damage at the edge or elsewhere.
I think they're one of the best deals in the line-up.
JonLeBlanc
Re: Z-Cut breakage
Post by JonLeBlanc »
Fri May 28, 2021 6:04 pm
Out of curiosity how big was the block of cheese?
it was like a 1/2lb block, so not very big
JonLeBlanc
Re: Z-Cut breakage
Doc Dan wrote:
Fri May 28, 2021 10:58 pm
he is from the South
hah, yessir
Woodpuppy
Re: Z-Cut breakage
Post by Woodpuppy »
JonLeBlanc wrote:
Sat May 29, 2021 8:17 am
hah, yessir
I reckon so :p
Robbob
Re: Z-Cut breakage
Post by Robbob »
JonLeBlanc wrote:
Fri May 28, 2021 10:16 am
Abyss_Fish wrote:
Fri May 28, 2021 10:11 am
Cheese’ll do it lol.
Where is the break? I assume if it’s mechanical failure and not something like the glue or molding coming loose over time it’d be covered. Also have you ran it through the dishwasher before? That tends to loosen handles and create pockets of inaccessible rust.
No dishwasher; I hand-wash all of my kitchen knives. There does appear to be some corrosion on the tang, however.
What drying method do you employ?
JonLeBlanc
Re: Z-Cut breakage
Robbob wrote:
Fri Jun 04, 2021 3:50 am
Dishtowel; I'm reasonably thorough.
JRinFL
Re: Z-Cut breakage
Post by JRinFL »
One more data point: My single example has been through the dishwasher a few times, does not get towel dried ever, and shows no corrosion to date. I think certain foods can be the major contributor to corrosion, not simple moisture.
Danvp
Re: Z-Cut breakage
Post by Danvp »
Posted this already a little while ago. Have several Z-cuts and like them a lot. Always reach for one in my kitchen drawer. This one my wife broke (really :D ). Don’t know how she did it. Maybe to much lateral pressure? I can’t imagine how one can break such a knife with normal use in the kitchen. No corrosion on them either.
Robbob
Re: Z-Cut breakage
Post by Robbob »
JonLeBlanc wrote:
Fri Jun 04, 2021 4:54 am
I wonder if some water seeps in between the tang and the handle, which, of course, would be out of reach for a towel. Corrosion sets in, and then you've got yourself a problem.
JonLeBlanc
Re: Z-Cut breakage
Robbob wrote:
Mon Jun 07, 2021 3:47 am
it's entirely possible
JRinFL
Re: Z-Cut breakage
Post by JRinFL »
I'm leaning towards some issue with the batch heat treating of the blades. Some few are getting over hardened.
tonijedi
Re: Z-Cut breakage
#32
Post by tonijedi »
This shouldn't happen.
I have a Spyderco utility knife that hasn't had any problem like this.
Among my other kitchen knives, it is machine washed frequently, put aside dirty, abused by my wife on ceramic plates.
Worm
Re: Z-Cut breakage
#33
Post by Worm »
Is it possible that the high temperatures during injection molding of the PP-handle,
which might be around 250 to 270 °C, reduce the mechanical properties and corrosion resistance around the tang area?
If I remember correctly that is what happens if you heat up a hardened blade too much.
At least the tang should see the full temperature of the molten Polypropylen during over-molding.
I have four Z-Cuts. No issues here. Haven't used them for hard cheese, yet.
Worm
Re: Z-Cut breakage
#34
Post by Worm »
For the interested folks out there, here how the Z-Cut blade tang looks like.
(I plan on putting on some nicer CF or wood scales, so I removed the original handle.)
There seems to be a date code on the tang like on the Golden folders.
Bill1170
Re: Z-Cut breakage
#35
Post by Bill1170 »
Interesting. Based on the photos from Jon and Worm, it appears that Jon’s tang broke at the first stress riser it found, the front edge of the “tooth” that hangs down to lock the tang into the polypropylene handle. I wonder if rounding that transition to the “tooth” would reduce the stress riser there (almost certainly) and weaken the bond to the plastic (unsure). A tooth that looked like a head on a neck like a jigsaw puzzle piece might provide a secure anchorage with less of a stress riser.
Re: Z-Cut breakage
#36
Post by Doc Dan »
JRinFL wrote:
Mon Jun 07, 2021 7:09 am
I think this is the most likely answer.
