Show your mods!
jackknifeh
#1861
Post by jackknifeh »
Ted and rorotech, both are beautiful. Ted, I've noticed your countersinking is nice. What type bit do you use? I think mine have a 135° angle tip. I use the same bits to countersink as I do to drill the hole, just bigger of course. The accuracy I'll take the blame for. That's another thinv about your work. Accurare. :)
Jack
Dustindk
#1862
Post by Dustindk »
Very nice done!
---------------Dutch-Knife-Collector---------------
Gofannon
#1863
Post by Gofannon »
ourgon wrote:Image
What did you made? Sandblast?
"The things you own end up owning you."
Tyler, Fight Club
:spyder: My spyderco :spyder:
Geoffrey
phillipsted
#1864
Post by phillipsted »
jackknifeh wrote:Ted and rorotech, both are beautiful. Ted, I've noticed your countersinking is nice. What type bit do you use? I think mine have a 135° angle tip. I use the same bits to countersink as I do to drill the hole, just bigger of course. The accuracy I'll take the blame for. That's another thinv about your work. Accurare. :)
Jack
Thanks, Jack!
Actually, most of the holes in the Urban and UKPK are COUNTERBORES instead of countersinks. This means that they have a flat-bottom to the hole, not a sloped bottom - which allows the bolts to snug up tight against the scales. To do this, you need to get counterbore bits which are sized for your needs. For each hole, there is the "pilot" hole (which goes all the way through), and the larger "counterbore" which creates the concentric hole for the head of the bolt to fit into.
For my workbench, I bought four or five counterbore bits with removeable pilot bits - and then bought a bunch of pilot bits. I can mix and match them to get the right sized holes for the knife I'm working on. The counterbore bits range in price, but most were in the $15 range, and the pilots are less than $5.
Here are the measurements for a few knives I've been working on:
URBAN
Pivot and Clip hole: 5/32"
Pivot and Clip counterbore: 1/4"
Backspring hole: 9/64"
Backspring counterbore: 11/64"
Scale thickness: 1/8"
UKPK G-10
All three holes: 5/23"
All counterbores: 1/4"
CAT/CHICAGO G-10
Pivot hole: 0.214" (I use a #3 drill bit)
Pivot counterbore: 0.313" (I use 5/16" counterbore)
Thong hole: 0.154" (I use a #23 or 5/32" bit)
Back spacer holes: 0.081" (I use #46 or 3/32" bit) - these holes are countersunk at 82 degrees, not counterbored
Scale thickness: 5/64"
DRAGONFLY 2 G-10
Pivot hole: 9/64"
Pivot counterbore: .204" (#6 bit)
Clip hole: 5/32"
Thong hole: 0.200" (#7 bit)
Scale thickness: 0.08"
Dustindk
#1865
Post by Dustindk »
He all this is the result of my first attempt of modding a spyderco!
im pretty happy with it! :)
- new g10 filed handles.
- all black spacers.
I think im gonne call it he "blackhawk"
[ATTACH]23377[/ATTACH] <----------Picture of it
Jazz
#1866
Post by Jazz »
Very nice, Dustin!
- best wishes, Jazz.
hom76
#1867
Post by hom76 »
My Domino modded with grooved scales and deep carry clip
Dexter
#1868
Post by Dexter »
Spyderco Endura 4 DuoColor (Grey and Orange scales) after:
- Scandi regrind
- double stone wash
- black wash (in FeCl3)
jackknifeh
#1869
phillipsted wrote:Thanks, Jack!
That's awsome. I'll search inet for counterbore. Do you suggest anywhere in particular to get these things? Lowe's for instance?
Jack
phillipsted
#1870
jackknifeh wrote:That's awsome. I'll search inet for counterbore. Do you suggest anywhere in particular to get these things? Lowe's for instance?
Jack
I get mine from ebay primarily. There is a dealer called "Drills and Cutters" I use - they have a decent selections of parts for a good price. The key is to get replacable pilot counterbores so you can swap them in and out to get the right sizes as you need them...
TedP
phillipsted
#1871
Finished a new UKPK mod this weekend. This one is made from a piece of unstabilized canarywood that I pulled from a scrap pile at my local wood dealer. I love this wood - it is hard and dense, but not resinous. It has a very uniform grain so it works easily. But the best part from my perspective is the almost rainbow colors in the stripes. It's hard to see the detail in the photo, but there are bands of tan, brown, black, red, yellow, and other colors in the grain. Beautiful stuff - although in my experience, the wood becomes less vibrant over the years with aging and exposure...
I sliced the slabs to thickness, sanded them flat, then drilled, counterbored, and cut them out. I reassembled the knife, and shaped and contoured with files and hand sanding. They are finished with three thin coats of hand-rubbed Tru-Oil topped with a buffing with Ren Wax.
Cheers!
TedP
LC Kid
#1872
Post by LC Kid »
Hi phillipsted!
That UKPK Drop Point is absolutely Gorgeous!
Stay Sharp!
Jazz
#1873
Post by Jazz »
Ted, Ted, Ted... you're becoming a master with the wood. Beautiful wood that is, too. Thanks for sharing.
ourgon
#1874
Post by ourgon »
jackknifeh
Dragonfly 2 - ironwood handle
#1875
Latest handle project for my Dragonfly 2.
Edit: ironwood scales and birchwood backspacer.
Birchwood backspacer
After post pic added: Pic of backspacer that is shaped along the curve of the blade edge. This brings the material closer to the tip when closed, which I think looks a little better. No effect on performance. There appears to be a "V" shape on the inside of the backspacer. This is one of those octipal delusions. :D It's flat. :)
Jack
EDIT PS:
I got the piece of birchwood from a forum member a long while ago. I hate to say I can't remember who it was. But I thank you all the same.
Forgot to add, this handle isn't finished. I noticed a flaw (:eek :) that I can live with for a few days. :rolleyes: I'll correct it soon. Can anyone tell what I'm talking about?
Another post post edit :) : I weighed the knife and it is 1.2 oz. which is the same weight as the specs. state on the FRN original. I was curious because it felt light. But, I've had c-tek/g-10 handle on it for a while which I assume is heavier. Never weighed it.
xceptnl
Post by xceptnl »
Jack, that Dfly looks very classy. I'd be happy to carry it for a year and write a review for you! ;) :D
*Landon*
jackknifeh
#1877
xceptnl wrote:Jack, that Dfly looks very classy. I'd be happy to carry it for a year and write a review for you! ;) :D
Very kind offer xceptnl, but dangit! :mad: @&*, I left my stamps in my other pants. :D
jackknifeh
#1878
jackknifeh
#1879
phillipsted wrote:I get mine from ebay primarily. There is a dealer called "Drills and Cutters" I use - they have a decent selections of parts for a good price. The key is to get replacable pilot counterbores so you can swap them in and out to get the right sizes as you need them...
TedP
I found counterbores on ebay but haven't found the seller. Can you give me a link to an item on this seller's site? I'll check his stuff first since you are happy with him. Or at least haven't had any problems I guess. :) Is there a way to search for sellers on ebay? All I know how to search for is products.
Jack
PS
I think I need to try tru-wax on my D'fly. Your knife is bootiful. :)
Jazz
#1880
Post by Jazz »
Jack, that Dfly is sweet. The contrasting backspacer really sets it off.
Ourgon, love that Endura.
