Show your mods!
jackknifeh
#1881
Post by jackknifeh »
Jazz wrote:Jack, that Dfly is sweet. The contrasting backspacer really sets it off.
Ourgon, love that Endura.
Thanks Jazz. One thing I've been wanting to mention about the one-piece handles. You can put or leave out the clip and/or lanyard hole. By leaving the lanyard hole out you can put the clip as high as you can for a very low riding knife in your pocket. Debating on putting the clip on this handle.
Jack
phillipsted
#1882
Post by phillipsted »
Nice work, Jack! It took me a minute to register that this knife started life as an FRN DFly! I thought for a couple of minutes that it was a rescaled G10 model. I'm liking this mod a lot!
(BTW, I spotted the "flaw" you were talking about, but I'll leave it up to someone else to say something... Otherwise, it is *perfect* ;) )
TedP
Donut
#1883
Post by Donut »
Is it that the right hand scale is smaller at the end furthest from the blade? (Seen in the third picture.)
It looks like you changed the profile of the handle. One of my favorite features of the Dragonfly is the angle at which my pinky finger lies on the scale.
-Brian
A distinguished lurker.
jackknifeh
#1884
Donut wrote:Is it that the right hand scale is smaller at the end furthest from the blade? (Seen in the third picture.)
Yes. This is caused when shaping the outside of the handle the Dremel is not at a 90° angle with the deck. See below.
I left the rear end of the handle wider (not thicker) for a bit larger end. I did this mainly so if I put a clip on it I have a little more room to make it really deep if Ileave out the lanyard hole.
But the flaw that I was actually talking about is the right scale is a tiny bit thicker than the left. This wasn't obvious to the naked eye until after I used the chamfer router bit on the edges. It took an issue that I couldn't see and made it more obvious. It's more apparant in the hand than in a picture. Easily fixable though.
Jack
razorsharp
#1885
Post by razorsharp »
Reground southard
razorsharp
#1886
Regrind, Horizontal satin, satin clip and heat anno to liner an Ti
RoBoTech
#1887
Post by RoBoTech »
Just finished up a TI Military and Cru-Wear blade swap.
Scales, back spacer, and clip are orange peeled. Lock face has been Cabonized. TI clip has been drilled and tapped for tip up carry.
And a Cru-Wear blade from a Sprint has been swapped in. Now I consider this a hard use knife, and is in my pocket.
I am now doing a Gold Anodized Fluted Ti. Just purchased a silver Fluted, new version. Sanded and polished the edges and groove tops. Flame ano'd the scales gold. Polished and flame colored the clip, and will do all the hardware the same, except the blade. Waiting for the custom standoffs and looking for someone to Carbonize the lock face and I forgot about the steel insert, and I am sure it softened from the heat when I flamed the scales.
Looking for a super steel blade. M4, M390, S90V, S10V. Will post that one when it's done. Here is a teaser.
Jazz
#1888
Post by Jazz »
Robo, how do you get the orange peel texture? Is it just with polishing? Nice, by the way.
- best wishes, Jazz.
RoBoTech
#1889
Post by RoBoTech »
Jazz wrote:Robo, how do you get the orange peel texture? Is it just with polishing? Nice, by the way.
I did what the youTube vid of TuffThumbz had shown. I use a coarse wire wheel, then a light polish.
You can see it here.
Here are a couple more teasers on my Gold Fluted TI mod. Still waiting for new stand offs and a blade donor. Also trying to find someone to carbodize the lock face.
Will do a final post when I get all the stuff done.
Holland
Post by Holland »
That looks incredible robo!
RoBoTech
#1891
Post by RoBoTech »
Thank you!
know of anyone who has a carbonizing machine? I hate to buy one to do 2-3 projects.
If anyone knows, please PM me.
phillipsted
#1892
This is my latest Spyderco Slipit - a Wharncliffe Urban that was purchased used from one of the Forums. It had been lightly carried, but not sharpened by its original owner. I made a set of scales using a scrap piece of unstabilized rosewood from my local lumber dealer. Trimmed up the board then resawed some 0.125" scale slabs. I sanded them smooth by hand, drilled and counterbored the holes, cut out the profile using a coping saw, then shaped and contoured the scales using files and sandpaper. I finished them by sanding out to 1200 grit and applying 4 thin hand-rubbed coats of Tru-Oil. This was the first time I'd had trouble with Tru-Oil adhering to an oily dense wood like rosewood. After the first coat, I had to sand it back and reapply using a new bottle. The subsequent coats went on smoothly, but I ensured that I rubbed the Tru-Oil in very thin coats and worked the oil into the pores well. It still isn't perfect, but I learned a lesson that I tried on a piece of left-over scrap wood. Next time, I'm going to apply a couple of base coats of Tru-Oil sanding sealer to seal the grain before applying the Tru-Oil as a top coat.
Cheers!
TedP
Spydersense
#1893
Post by Spydersense »
Another great piece Ted. Nice work!
Time for another :spyder:!
-Matt
Jazz
#1894
Post by Jazz »
Nice, Ted. Looks so smooth.
USNGMG2
#1895
Post by USNGMG2 »
I modified the Superleaf due to someone else's poor attempt. The blade was convexed, the spine now has a bevel and the top plunge line moved to the rear. The blade was polished to 800 grit. The handle was modified fore and aft.
MadRookie
#1896
Post by MadRookie »
Nice work there Ted!
Wooden scales always seems to warm up a knife a notch or two.
jackknifeh
Backspacer on my D'fly 2 ironwood handle broke (sad face)
#1897
I made this handle with ironwood handle with a birchwood back spacer. The bottom of the backspacer where the lock spring applies pressure broke off inside the handle. I don't think I used enough epoxy right there. I was afraid if I used too much it would squeeze out into the lock spring slot. After it dried I wouldn't be able to insert the lock spring. This time on the new back spacer I made sure I had enough epoxy there as well as I drilled a couple of real small holes through the backspacer under the lockspring slot and into the side of each scale. With the epoxy going all the way through I'm hopeing it will act like a tiny metal rod increasing strength. Anyway, this time I used elephant ivory for the new backspacer. Sorry elephant. I had a small piece in with a bunch of pieces given me by a forum friend. I think it looks pretty good. I hope it lasts forever. This handle may have a super blue blade in it some day. :)
Here is the new backspacer from the top.
This is the bottom.
This is the handle if you forgot. They don't show up as clear in the picture but this handle is getting quite a few tiny scratches from use and being in the pocket. Character,,, right? :)
xceptnl
Post by xceptnl »
I think the Ivory and the scratches enhance the character Jack. Now you need to mirror polish that blade and fully crown the spine.
*Landon*
jackknifeh
#1899
xceptnl wrote:I think the Ivory and the scratches enhance the character Jack. Now you need to mirror polish that blade and fully crown the spine.
Sounds like a challange to me! I'll give it a try. Bet it would look good. Give me 3 minutes. :rolleyes: :)
Jack
xceptnl
Post by xceptnl »
jackknifeh wrote:Sounds like a challange to me! I'll give it a try. Bet it would look good. Give me 3 minutes. :rolleyes: :)
Jack
Go...
*Landon*
