I cleaned and scrubbed my diamond SM rods and set them up at 15dps. I started off with 20 passes a side then went to alternating single passes, holding the knife only to the extent that I could keep the angle upright and consistent. The weight was only the weight of the knife. I didn’t hold the base of the SM, so as to ensure that the pressure stayed super light.
I tried to get some ‘before’ shots of the edge through a loupe, but it didn’t focus very well.
Here’s the knife before:
As mentioned I’ve been thinning it out behind the edge with the 240 OCB Venev. I haven’t started blending the bevel polish.
The microchipping is barely visible with the naked eye, but you can feel the edge catching and stuttering on junk mail catalogue paper.
After grinding all the chips out and reestablishing a fresh, clean shaving apex on the 400 grit diamond rods, I finished with a few ultra light alternating passes, then two light passes per side on 3 micron diamond pasted balsa, and another couple of passes per side on 0.1 micron diamond emulsion smoothside leather.
It took a lot of willpower not to refine the edge on the brown or white rods, lol. :D
I suppose I could have run the edge angle at 20dps for extra durability, but I’ll see how that edge performs for a few days.
I made a few new balsa strops today on hardwood backing, so the next experiment will be to try the 60 micron diamond paste from Venev.
Sounds like you scored a real keeper there, Turbo! :Dbbturbodad wrote: ↑Sat Oct 26, 2019 8:39 pmYep my wife is a jeweler and I steal borrow lapping films and tools from her all the time. :D
