twinboysdad wrote: ↑Fri Mar 11, 2022 6:42 amMark Greenman had an Ayoob Krein regrinded FFG, wonder if he could comment on performance? @markgreenmanEvil D wrote: ↑Fri Mar 11, 2022 2:18 amAs much as I'm not really a huge fan of low height hollow grinds, I don't think this model would work in FFG unless the blade shape was changed into a much taller blade height, and I'm sure that's not going to happen. On a short blade like this there just isn't enough room for the flat grind to transition from edge to spine without it being a door stop. Even the Nilakka is a wedge, but it gets away with it by being a near zero grind. This blade would be stupid thick behind the edge if it was done in FFG. This just isn't a slicing sort of design.
I think I've seen it before. Seems it would either need to be very thin at the edge or at the spine or both.
