twinboysdad wrote: ↑Fri Mar 11, 2022 6:42 amMark Greenman had an Ayoob Krein regrinded FFG, wonder if he could comment on performance? @markgreenmanEvil D wrote: ↑Fri Mar 11, 2022 2:18 amAs much as I'm not really a huge fan of low height hollow grinds, I don't think this model would work in FFG unless the blade shape was changed into a much taller blade height, and I'm sure that's not going to happen. On a short blade like this there just isn't enough room for the flat grind to transition from edge to spine without it being a door stop. Even the Nilakka is a wedge, but it gets away with it by being a near zero grind. This blade would be stupid thick behind the edge if it was done in FFG. This just isn't a slicing sort of design.
I think I've seen it before. Seems it would either need to be very thin at the edge or at the spine or both.
 It just offends my eyes. The Delica is okay.
