Spyderco Amsterdam Meet 2023 Report
Mr Blonde
Lil’ Native Lightweight – Spyderco Design Production Sample 2023
#101
Post by Mr Blonde »
The Lil’ Native Lightweight features a really light and compact blade, even compared to the MicroJimbo and Lil’ Native Wharncliffe. The linerless FRN handle truly makes the Lil’ Native a featherweight. The Lil’ Native Lightweight is very similar to the lightweight Dragonfly.
Specifications
Closed: 3.47 inch/ 88 mm
Overall: 5.92 inch / 150 mm
Blade: 2.45 inch / 62 mm
Edge: 2.05 inch / 52 mm
Thickness: 0.125 inch / 3.2 mm?
Steel: CPM S30V
Weight: 1.55 oz / 44 g
Grind: Full-flat
Lock: Back Lock
Handle: FRN
Carry: Ambi
Clip: Tip-up
Origin: USA
I have no information on pricing or release dates.
Last website update: 09-11-2025 Instagram
Re: Spyderco Amsterdam Meet 2023 Report
#102
Interesting to see a back lock - I thought the comp lock had won out for this model.
Guts
#103
Post by Guts »
Not sure if I like the Microjimbo or the Lil Native Wharnie better :thinking Probably end up with both though :rofl
#104
Microjimbo and Lil Naive LW back to back!!! Hardly gets better than that! :smiling-heart-eyes :party-face
I find it interesting that the Microjimbo blade is listed at 1.97” as I would’ve expected it to be closer to 2.5 inches. Still 110% in on that one.
Still hoping for some actual new designs though! :crossed-fingers
Mr Blonde
Manbug Leaf – Spyderco Design Production Sample 2023
#105
Post by Mr Blonde »
The Manbug will be offered in a leaf shape blade, after customer demand for this blade style option of the Manbug. It basically is a micro-version of the double distal triangle blade shape that Spyderco is known for.
Specifications
Closed: 2.51 inch / 64 mm
Overall: 4.46 inch / 113 mm
Blade: 1.95 inch / 49 mm
Edge: 1.72 inch / 44 mm
Thickness: 0.098 inch / 2.5 mm
Steel: VG-10
Weight: 0.78 oz / 22 g
Grind: Full-flat
Lock: Back Lock
Handle: FRN
Origin: Japan
Mr Blonde
#106
Post by Mr Blonde »
Mushroom wrote:
Fri Mar 10, 2023 9:52 am
There's always the option I made a mistake or it was measured slightly differently than Spyderco would....
#107
Some very interesting things coming our way . MG2
Mr Blonde
Counter Critter – Spyderco Design Production Sample 2023
#108
Post by Mr Blonde »
The Counter Critter is a larger version of the Counter Puppy (also shown for comparison), which was released in 2020. Eric explained that this design follows a trend that started a few years ago in Japan, to make kitchen knives that you can put down without the edge touching the table. The 7CR17 steel uses less carbon than most other steels used by Spyderco. The idea behind this is that the steel will still perform fairly well, and that it resists more ‘abuse’; people would probably put it in a dishwasher since it’s a knife made in China. The Counter Critter will also come with purple handles in the future, as well as a serrated edge.
Specifications
Overall: 8.39 inch / 213 mm
Blade: 3.95 inch / 100 mm
Edge: 3.75 inch / 95 mm
Thickness: 0.080 inch / 2.0 mm
Steel: 7Cr17
Weight: 1.6 oz / 45g
Grind: Full-flat
Handle: Plastic
Origin: China
Mr Blonde
SharpKeeper – Spyderco Design Production Sample 2023
#109
Post by Mr Blonde »
The SharpKeeper will be a basic accessory to protect your kitchen knife. The holes help to keep moisture down. The inside is lined with a velvet-like material to help guide and ease the knife in the cover. I’m not sure what the material is, but it felt a lot like Boltaron or Kydex/Concealex.
Specifications
• width: 0.98 inch / 26 mm - tall: 2.75 inch / 70 mm
• width: 0.98 inch / 26 mm - tall: 3.82 inch / 97 mm
• width: 0.98 inch / 26 mm - tall: 4.80 inch / 122 mm
• width: 0.98 inch / 26 mm - tall: 7.24 inch / 184 mm
• width: 1.50 inch / 38 mm - tall: 8.07 inch / 205 mm
• width: 1.50 inch / 38 mm - tall: 9.45 inch / 240 mm
#110
Ooph, those sharp keepers look nice. The lining is clutch.
#111
Did Spyderco make any mention of why the holes are offset the way they are on those sheaths? Was a straight line just too simple? I don’t have OCD but looking at those sheaths makes me feel like I do!
Mr Blonde
#112
Post by Mr Blonde »
These were the last photos I have to share from the Spyderco Amsterdam Meet 2023. I do have some videos I'm working on...
Guts
#113
Post by Guts »
Mr Blonde wrote:
Fri Mar 10, 2023 10:40 am
Thanks for all the hard work!
olywa
#114
Post by olywa »
Noticed that the specs for the Lil Native LW above show a blade thickness of 3.2mm. It was my understanding that the LW was supposed to be thinner blade stock. Did I get that wrong?
aicolainen
Re: Lil’ Native Lightweight – Spyderco Design Production Sample 2023
#115
Post by aicolainen »
Mr Blonde wrote:
Fri Mar 10, 2023 9:41 am
The Lil’ Native Lightweight features a really light and compact blade, even compared to the MicroJimbo and Lil’ Native Wharncliffe. The linerless FRN handle truly makes the Lil’ Native a featherweight. The Lil’ Native Lightweight is very similar to the lightweight Dragonfly. However, the Lil’ Native features a 4-way clip mount option and it’s made in the USA, like all Native designs.
Specifications
Steel: CPM S30V
Grind: Full-flat
Lock: Back Lock
Handle: FRN
Carry: Ambi
Clip: Tip-up
Origin: USA
Thank you for yet another batch of pictures and interesting insight!
Is it possible that your thickness measure could be off? I’m pretty sure Eric at some point said the LW would come with a thinner blade stock
Mr Blonde
#116
Post by Mr Blonde »
aicolainen wrote:
Fri Mar 10, 2023 11:03 am
Specifications
Steel: CPM S30V
Grind: Full-flat
Lock: Back Lock
Handle: FRN
Carry: Ambi
Clip: Tip-up
Origin: USA
That is very possible, I think I went with the catalog listing for the regular lil native.
Mr Blonde
#117
Post by Mr Blonde »
olywa wrote:
Fri Mar 10, 2023 10:57 am
I could very well be off, I didn't get a good measure of it and went with the catalog listing for the regular lil Native.
aicolainen
#118
Thanks! There is still some hope then :)
wrdwrght
#119
Post by wrdwrght »
Wow, just wow! Thanks Wouter for returning to your splendid Springtime gift-giving.
A LW Native Chief? A Lil’Native Wharncliffe? A Military2 AND a MagnaCut PM2?!
All will get my money.
I’ll have my first BD1N, the wharnie by Eric that the Q-Ball could have been, a PM2 XL, and a presumed Salt PM2 with the Caribbean’s fantastic G10 grippiness (but without the yellow I happen to like).
Now, if Spyderco would only offer an invisibility cloak to wrap around any one these or my other Spydies, they would not need to languish at home whenever I one-bag it somewhere by air.
#120
Lil Native FRN looks like the best of both worlds... Backlock and Wireclip. I'm in.
