BLASPHEMY! :eek:
I just want to try a recurve like this in full SE. The heel/middle will perform like a hawkbill while the tip will perform like a standard bellied blade. It's not just the best of both worlds, it IS both worlds.
Precisely!
(yes of course I disinfected it first lol)Evil D wrote: ↑Thu Apr 09, 2020 8:31 am
Hmm I'll see what I can do. We have an international food market here that likely has fresh ones but with the virus crap going on I'm not sure I can go there, it's across the state line and they're threatening to quarantine people who leave the state. I'll check for it locally too.
It amazes me how much abuse and neglect this knife can take. I treat mine like a red-headed step child, it just shrugs it off and keeps going. It's starting to get personal, like it's calling me a punk b!+$#.Evil D wrote: ↑Sat Apr 11, 2020 5:01 am
It gets used daily but I've stuck with the same knife (leaf blade) for all these tests just to see how it handles extended hard use. This is as much a test of the Caribbean model as it is of the steel and edge type. I'm not sure blade shape would have made much difference in these tests since most of the cuts were made around the center of the edge/belly where both knives are pretty much the same.
Sumdumguy wrote: ↑Sat Apr 11, 2020 5:15 am
I treat rental cars better than I treat this knife!
What will kill it? Like a Tootsie Pop, "The world may never know."
:spyder:
ladybug93 wrote: ↑Sat Apr 11, 2020 10:11 ami typically love a leaf shaped blade, but i think i love the look of your modded sheepsfoot even better, especially with how similar the blade is to a wharncliffe. i’ve never ground a blade before. have you considered a thread dedicated to the process you went through modding your sheepsfoot version? i don’t tend to do heavy modding on knives, but your work with that knife might just inspire me to grab one and really make it mine.
It's an amazing thing, sir. A marvel of modern materials and design.
well, it looks great. that picture you shared of it made me want a caribbean even more. i’ll probably do something similar to yours and shave off a little of the hook like we’ve discussed in the past. i gotta wait until the cqi is done and they start rolling out again though.Evil D wrote: ↑Sat Apr 11, 2020 10:33 amladybug93 wrote: ↑Sat Apr 11, 2020 10:11 ami typically love a leaf shaped blade, but i think i love the look of your modded sheepsfoot even better, especially with how similar the blade is to a wharncliffe. i’ve never ground a blade before. have you considered a thread dedicated to the process you went through modding your sheepsfoot version? i don’t tend to do heavy modding on knives, but your work with that knife might just inspire me to grab one and really make it mine.
It's really simple if you have a Dremel, just take your time and keep the blade cool by dipping it in water. Think of it like carving a curve into a stick. I usually draw out the curve I'm imagining in Sharpie and then carve away with the Dremel much the same as you'd cut off a slice of apple, pulling the Dremel down the spine towards my thumb. If you take it slow and steady it's hard to screw up. Since I use a sanding barrel it isn't exactly easy to remove metal which makes it a bit safer since it's a slow process. I originally thought I wanted a reverse tanto shape but after I drew that out on the blade it look more like a broken tip repair than what I had imagined so it ended up the way it is now.
ladybug93 wrote: ↑Sat Apr 11, 2020 3:47 pm
