LC200N / Caribbean SE torture test gauntlet of death
Re: LC200N / Caribbean SE torture test gauntlet of death
#101
Sumdumguy wrote:
Tue Apr 07, 2020 11:21 am
To a very special friend ;)
As for the Ulize, the blade shape makes SE less necessary. Infact, it's probably my new favorite blade shape. Truly a beast, fiercely competing with the Caribbean.
BLASPHEMY! :eek:
I just want to try a recurve like this in full SE. The heel/middle will perform like a hawkbill while the tip will perform like a standard bellied blade. It's not just the best of both worlds, it IS both worlds.
Sumdumguy
#102
Post by Sumdumguy »
Evil D wrote:
Tue Apr 07, 2020 1:31 pm
Precisely!
It has been ideal, for everything I've used it for. Especially oranges... I can't express how nice that function is for me.
This knife in full LC200N, would be a knockout! Don't change anything, just make all the parts out of LC200N. SE option, because why not?
FFG, maybe. But, the hollow grind has been fantastic. It's pretty high and the blade is very thin. I'd be okay with it staying HG.
-Thomas Jefferson
#103
Just cut up some flank steak. Edge retention was not an issue, no edge damage :cool:
Image (yes of course I disinfected it first lol)
Woodpuppy
#104
Post by Woodpuppy »
Evil D wrote:
Tue Apr 07, 2020 3:27 pm
I bet you took years off the life of your cutting board though
#105
Evil D wrote:
Sun Mar 29, 2020 3:07 pm
Food prep? .....
David, concerning "food prep": Go for a coconut, if you like... ;)...(not just kidding though, would be interesting indeed...)
#106
Thu Apr 09, 2020 8:21 am
Food prep? .....
Hmm I'll see what I can do. We have an international food market here that likely has fresh ones but with the virus crap going on I'm not sure I can go there, it's across the state line and they're threatening to quarantine people who leave the state. I'll check for it locally too.
#107
evild, have you done any testing with the modded sheepsfoot you posted a while back?
#108
Evil D wrote:
Thu Apr 09, 2020 8:31 am
Food prep? .....
Please don't do anything just even slightly out-off-the-way-stuff just for that coconut!! :eek:
There'll come better times, but then I'd be certainly interested to see what the Caribbean SE can do to a coconut if you'd like to run that test... :rolleyes:
#109
Sat Apr 11, 2020 3:42 am
It gets used daily but I've stuck with the same knife (leaf blade) for all these tests just to see how it handles extended hard use. This is as much a test of the Caribbean model as it is of the steel and edge type. I'm not sure blade shape would have made much difference in these tests since most of the cuts were made around the center of the edge/belly where both knives are pretty much the same.
Sumdumguy
#110
Post by Sumdumguy »
Evil D wrote:
Sat Apr 11, 2020 5:01 am
It amazes me how much abuse and neglect this knife can take. I treat mine like a red-headed step child, it just shrugs it off and keeps going. It's starting to get personal, like it's calling me a punk b!+$#.
I treat rental cars better than I treat this knife!
What will kill it? Like a Tootsie Pop, "The world may never know."
:spyder:
-Thomas Jefferson
#111
Sumdumguy wrote:
Sat Apr 11, 2020 5:15 am
:spyder:
Hard to say, I would love to see some failure testing of pretty much every knife Spyderco makes. The pivot is smaller than I realized, I initially thought it was huge until I compared it to a Military/Para 2 bushing pivot, so I wonder if it would benefit from a larger pivot.
Something I've given a lot of thought to lately is how the compression lock and liner locks are limited to a certain size washer, at least on the lock bar side. I would make the switch to back locks just for larger diameter washers, but overall it seems that Spyderco tend to run smaller diameter washers than a lot of other companies. I'm not sure why they don't run offset sized washers like CRK do on the Sebenza, they could run a much larger washer on the non lock side on compression lock knives and that would go a long way towards controlling blade play. That plus a larger bushing pivot would make it a sturdier knife.
Sumdumguy
#112
Post by Sumdumguy »
I've not experienced any blade play with a compression lock aside from the Ti A.T.R, but I've got that figured out(just gotta take the time to send it off).
Not that I dislike backlocks, they are in my top two. However, they have more "play" than any compression lock I've ever seen. The lock rock that's present on almost all the backlocks, while not concerning, is "play". My Caribbean and all prior compression locks have been completely free of play, like bank vaults. I'll take either, but I slightly prefer the comp.
As for the pivot, who knows? It has not been an issue as of yet. Bigger would be fine, but at that level of failure, I can't imagine the added pivot thickness is going to provide a huge increase in durability. At the level of stress required to cause the pivot to fail, there are so many different pieces around the pivot that could fail, the increase in durability of that one component is negligible.
There's an equation somewhere that could quantify this, diminishing returns or something like that.
Let me know when your pivot fails. If it ever does, I wanna see the aftermath! :p
-Thomas Jefferson
#113
Sumdumguy wrote:
Sat Apr 11, 2020 8:07 am
It would take something really stupid like maybe batoning a coconut or excessive prying. Some of these tests are about the hardest I've used any knife ever and aside from some scratches and sharpening this knife is basically still new.
James Y
#114
Post by James Y »
This thread makes me wish my Caribbean was SE (even though I do like my PE Caribbean). :)
#115
James Y wrote:
Sat Apr 11, 2020 9:10 am
Everything is better in SE ;)
Pretty good excuse to get another one, get whatever the other blade shape is that you don't have in SE for variety.
#116
i typically love a leaf shaped blade, but i think i love the look of your modded sheepsfoot even better, especially with how similar the blade is to a wharncliffe. i’ve never ground a blade before. have you considered a thread dedicated to the process you went through modding your sheepsfoot version? i don’t tend to do heavy modding on knives, but your work with that knife might just inspire me to grab one and really make it mine.
#117
Sat Apr 11, 2020 10:11 am
It's really simple if you have a Dremel, just take your time and keep the blade cool by dipping it in water. Think of it like carving a curve into a stick. I usually draw out the curve I'm imagining in Sharpie and then carve away with the Dremel much the same as you'd cut off a slice of apple, pulling the Dremel down the spine towards my thumb. If you take it slow and steady it's hard to screw up. Since I use a sanding barrel it isn't exactly easy to remove metal which makes it a bit safer since it's a slow process. I originally thought I wanted a reverse tanto shape but after I drew that out on the blade it look more like a broken tip repair than what I had imagined so it ended up the way it is now.
Sumdumguy
#118
Post by Sumdumguy »
Evil D wrote:
Sat Apr 11, 2020 9:08 am
It's an amazing thing, sir. A marvel of modern materials and design.
-Thomas Jefferson
#119
Evil D wrote:
Sat Apr 11, 2020 10:33 am
well, it looks great. that picture you shared of it made me want a caribbean even more. i’ll probably do something similar to yours and shave off a little of the hook like we’ve discussed in the past. i gotta wait until the cqi is done and they start rolling out again though.
#120
Sat Apr 11, 2020 3:47 pm
I don't think you can make the butt of the handle as narrow as a Manix 2 but you should be able to round it off quite a bit before exposing the tip/edge becomes an issue, especially if you get the sheepsfoot version.
