Hey Sal - is this a trademark infringement?
You know, I'm not sure. I believe the trademark is for a circle opener on folding knives and the fixed blades get it out of homage.
To make most fixed blades you NEED holes to use screws/pins to attach the scales. They don't need to be visible like the pictured one.
I bet you the hole is there for lanyard use. It would be somewhat odd for fixed blade makers to not be able to use a circle hole for lanyards.
-Brian
A distinguished lurker.
The picture that Donut posted is NOT from the link I posted. What Donut posted does not raise any question in my mind. The knife in the link does, however. It has a hole in the blade forward of the handle, and an additional hole at the butt and the picture on the site even shows a lanyard there. I think they market the hole in the blade as a place to strike a ferro rod.
+1Chumango wrote:The picture that Donut posted is NOT from the link I posted. What Donut posted does not raise any question in my mind. The knife in the link does, however. It has a hole in the blade forward of the handle, and an additional hole at the butt and the picture on the site even shows a lanyard there. I think they market the hole in the blade as a place to strike a ferro rod.
Look at the picture. The lanyard does not prevent the possibility of losing your grip, it mitigates what the blade will do if it happens. Blade Sports compitition rules addresses the lanyard hole placement specifically.Donut wrote:I'm confused. How do you tie your lanyards with a fixed blade so you don't lose grip of the knife?
Best...
Here is what I found on the trademark.
"The mark consists of the configuration of a portion of the goods, namely a circular through hole formed in the body of a knife blade"
It looks like ANY circular hole through the blade is the wording of the trademark.
-Brian
From what Sal has posted in the past, the trademark covers a round hole in a specific location on the blade. Judging by the hole placement on my other Spyderco fixed blades, I would say the hole on the Vultureworks knife is too far back to infringe on the Spyderco trademark.
