Took apart the Endura 4 for a detail cleaning Pics
Thanks for taking the time to photograph the process, swigert. Non-experts, like myself, really get a lot from visual tutorials.
Always heard: taking apart a Spyderco (to clean/lube) voids the warranty. Always wondered: how exactly could they tell? Perhaps it's an honor code type of thing....
Regardless, thanks for your informative post.
“Damned infernal gizmo. My kingdom for a left-handed can opener!" — Mr. Burns, The Simpsons
Thank you, Mr. Sal Glesser ... and Mrs. Gail Glesser![/b][/color]
- this_is_nascar
- xceptnl
Based on my educational background as well as my (limited) experience from taking knives apart, I think the needed pieces are represented in that picture. I have seen the Delica taken apart dozens of times and this was the first I have seen an Endura. The parts are very similar, yet the shape is unique to the Endura.this_is_nascar wrote:Does that picture depict mechanically the way that all Spyderco back-lock knives (such as the Chaparral and Caly 3.5) work?
I did a cleaning in one of my enduras and ended up switching FRN on two of them, they look much nicer. The foliage green with a FFG and the brown with a combo edge. The design is so simple and so fool-proof but there is a small trick to it, you have to engage the lock pin at the very end so everything can line up. If not the spacer might not line up properly.
Keep'em sharp
Enduras, Stretch, PM, Manix…Steels k390, M4, Rex45, cruwear, MagnaCut
Fred Sanford
The Caly is the same, except for a steel spring holder.(plastic)
The Chaparral adds a stud stop for the blade.(superior design)
My Chap had a "dragging" blade, glad I took it apart. The stud stop was a tiny bit long and dragged on the CF scale. Took off a bit of the stud (in length) and the blade just drops when unlocked. :D
SCARAMOUCHE!
Laethageal
That thought you guys have about opening up a knife and losing warranty is totally wrong. What will void the warranty is if you break something while doing so. Or if you reassemble it wrong and cause failure. If you read the warranty info on their webpage:
Repairs to your knife performed by any source other than Spyderco Inc. unconditionally voids the knife’s warranty.
Spyderco’s warranty does not cover damage caused by abuse, misuse, loss, improper handling, alterations, accident, neglect, disassembly, or improper sharpening.
Disassembly of a knife to clean it isn't considered repair, and thus the first line does not apply.
Unless you damage the knife during disassembly, second line doesn't apply either for that particular purpose.
If it's not polished, call it a saw, not an edge!
Thanks for the clarification. Careful disassembly for cleaning should be allowed. Good to know it is.Laethageal wrote:That thought you guys have about opening up a knife and losing warranty is totally wrong. What will void the warranty is if you break something while doing so. Or if you reassemble it wrong and cause failure.
- this_is_nascar
Interesting. My blade is not flickable and will not drop on its own when unlocked. I just assumed it was designed to be that way. Which piece are you saying is plastic? Not sure I'm real fond of that.gull wing wrote:The Caly is the same, except for a steel spring holder.(plastic)
"The only way to stop a bad guy with a gun is a good guy with a gun". --- Wayne LaPierre 12/21/2012
How was the reassembly for you ? Did you not find a bit tricky to realign the 4 metallic spacers/pins and the plastic pin of the back spacer to put the 2nd liner back in place ?swigert wrote:
Hopefully someone finds this useful, if anyone has any questions about disassembly and reassembly I would love to answer them and be of any help I can.
| C10PGRE + C10FPK390 Endura 4 | C28GPFG Dragonfly | C36TIP Military | C41GP5 Native 5 | C54GPBN Calypso | C65CFP Lum Chinese | C81GPDBL2 PM2 | C90GFPD Strectch | C94TIP UK Penknife | C101PGY2 + C101PBORE2 Manix 2 | C113GPGY Caly 3 | C123TIP Sage 2 | C126GPFG Rock Lobster | C135GP Perrin PPT | C144CFPE Caly 3.5 | C163PBK Pingo | C164GPBN Nilakka || MT16P MT17P MT18P Mule Team |
- _centurio_
- _centurio_
What do you have to back this up? Tazkristi has said numerous times that DISASSEMBLY voids the warranty, no qualifiers. Refer to this thread and specifically post 4.Laethageal wrote:That thought you guys have about opening up a knife and losing warranty is totally wrong. What will void the warranty is if you break something while doing so. Or if you reassemble it wrong and cause failure. If you read the warranty info on their webpage:
http://www.spyderco.com/forums/showthre ... post754418
That said, I've never needed to disassemble one of my Spydercos but feel I could successfully accomplish the task without breaking anything and trying to claim the warranty. I'm sure most forum users here are capable as well.
Chris
Chris
- Surfingringo
Hi Swigert, re: your op, I think the stretch will make a great hunting knife. Have you considered the superblue version? I just got a delica in superblue and this steel seems pretty amazing so far!
Umm...on a completely unrelated note, do you have any legitimate explanation for why you don't own a Military yet?? Seriously man, I think you will really like the Millie! Resistance is futile! :D
- Surfingringo
