Project: Ultimate EDC Rotation...
gbelleh
#201
Post by gbelleh »
Nilakka
The Spyderco Nilakka is one of those unique, interesting, ethnic series knives that sets Spyderco apart from all the rest. Photos of the Nilakka immediately grabbed my interest with its distinctive Puukko shape. But, it wasn't until I held one at a gun show that I truly could appreciate just how amazing this knife really is.
First, I'll talk about the background and specs: The Nilakka is a folding knife designed by Pekka Tuominen, who also designed the fixed blade Spydero Puukko (which is also a fine piece of work). The Nilakka has a 3.5" CPM-S30V blade, with a Scandi, "zero-ground" edge. I'm not too sure about the edge because apparently, Spyderco recalled these, very early on, to put a small bevel on it to help with durability. At least, I think that's what happened. Please correct me if I'm mistaken. Anyway, whatever they did with the edge, it's an absolute slicing demon (more on that later). The blade is thick, at 4.5mm, but a swedge cut along the top, allows the blade to narrow to a very fine point. Handles have skeletonized, stainless liners, under brown G-10 scales with a light texturing applied to the surface. A solid, steel backspacer takes up almost half the spine. A tip-up, right side, deep carry pocket clip is mounted to the butt end of the handle by two Torx screws.
The handle of the Nilakka is different. Its scales are machined into a triangular shape, giving the handle a hexagonal shape like I've never seen before. This shape is actually quite comfortable in use, and was more ergonomic in the hand than I expected by looking at the pictures.
There is no jimping anywhere on this knife, though the lock bar does have three small scallops machined into it, which really do offer just a bit of traction for easy closing. The deep cutout in the scale also allows for easy access to the Spydie hole, which is on the small side. I find it a very easy knife to open and close under normal conditions, however, the Nilakka is not a particularly lefty friendly knife.
The Nilakka weighs in at 5 oz. I don't find it overly heavy, but it does have some heft to it. That solid backspacer seems to add quite a bit of rearward weight, especially noticeable when the knife is closed. When open, it's very well balanced in the hand, and doesn't seem overweight at all.
In the pocket, the somewhat thick, hexagonal shape of the Nilakka's handle, and its 5 oz weight, make it more noticeable than most of my regular EDC options. I also find the Nilakka a bit difficult to extract from my pocket. I'm not sure why, but I notice that the clip makes contact with the G-10 scale, only on the very edge of the clip, and only on the vertex of the triangularly machined scale. The clip is also very strong. This positioning seems to create a lot of friction initially when trying to remove the knife. The ultra low riding position also means there is little to grab onto. But this is only a small issue for me.
The liner lock of my Nilakka locks up early, and solidly. The blade glides open smoothly. Fit and finish are incredible as usual from Taichung. The Nilakka has a very high-tech, precision built feel to it, and I can't really see any flaws on this handheld, piece of acuminate sculpture.
On to cutting… wow! This is probably the sharpest knife I've ever used. I'm no expert when it comes to edges, but the bevel on this blade is tiny, and incredibly even and precise. I haven't used this knife all that much yet, but it opens mail with an effortlessness I've never experienced. The first time I opened a letter with it, I swore I had missed getting the blade under the flap, and had just cut through air. But no, the envelope was opened with as clean a slice as I've ever seen. It really is an impressive edge. But, it makes me very hesitant to go cardboard cutting with it, or worse. This thing is a pocket laser!
To me, the Nilakka has an unusual vibe to it. Both ultra modern, and retro at the same time. Something about the hexagonal handle shape reminds me of the geometric, minimalist sculpture of the 1960s, while the brown scale color and wood-grain-like texture is reminiscent of vintage wood furniture that would be found in a den with many leather-bound books that smells of rich mahogany.
The Nilakka, as a folding Puukko, is a very nice package. Compared to the fixed blade Puukko, the Nilakka's blade and handle are very comparable in size and function.
But only the Nilakka can fold neatly, and ride comfortably, clipped in the pocket. The fixed blade Puukko in its sheath is much bulkier.
Overall, I'm very impressed with the Nilakka, and I put it up there with the Chokwe as far as interesting and unique Spydercos that are more functional and comfortable to use than pictures might suggest. IMO, there are probably better all-around EDC choices out there, and the Nilakka won't be for everyone. But it will remain an occasional user in my rotation, and will definitely be kept handy in my office. My Nilakka will be appreciated for its uniqueness and usefulness for years to come.
:bug-red-white
BigBaldGuy
#202
Post by BigBaldGuy »
My EDC, back pocket Ulize, strongside front is typically a Salt, Manix 2, or a Stretch. Weak side front typically an assisted opener of some kind only because I have not got the snap down off handed. A multi tool and pen light are with me always as well.
gbelleh
#203
Post by gbelleh »
Welcome BigBaldGuy, you pack a lot of blades!
:bug-red-white
DougC-3
#204
Post by DougC-3 »
Thanks for another great photo review, gbelleh. For the first time, I feel as though I know something about this knife. This is about as close to handling one as it gets.
Note to self: Less is more.
gbelleh
#205
Post by gbelleh »
I just wanted to share this excellent video by edgeobserver showcasing the Nilakka. It really captures what I tried to convey in my review. The Nilakka's design and build quality are truely incredible.
:bug-red-white
DougC-3
#206
Post by DougC-3 »
Very good, informative video. Interesting about the micro bevel. The video seems to support what you said about that, unless it's where you got the idea to start with :)
jabba359
Post by jabba359 »
I don't know how I missed this thread before, but am glad I clicked on it today. Thanks for using and reviewing all these knives.
-Kyle
:bug-red
http://www.spydiewiki.com
gbelleh
#208
Post by gbelleh »
I'm in the process of setting up a YouTube channel for video reviews. I want my reviews to contain all the useful information people need to make informed purchase decisions, and very high quality close-up video of the items, along with size comparisons.
I would keep them concise, with no rambling tangents, but I also want them to be entertaining. Short cutaways with characters, short skits, music, graphics, green screen effects, etc.
Just wanted to get some opinions. Do you enjoy a little humor here and there in these reviews? Or do you prefer all business, no nonsense reviews?
Would you prefer to watch YouTube videos with good info and product shots, but also short comedy bit cut-ins along the way? Or not.
It's more work to make them funny, but I enjoy video editing, so it makes it more fun for me. And would be different from all the other reviews out there. Let me know if you have an opinion.
:bug-red-white
xceptnl
Post by xceptnl »
gbelleh wrote:I'm in the process of setting up a YouTube channel for video reviews. I want my reviews to contain all the useful information people need to make informed purchase decisions, and very high quality close-up video of the items, along with size comparisons.
I am certainly interested in quality knife reviews. I tend to prefer more serious, in depth, detail oriented, usage based reviews. This is not to say I don't enjoy a laugh, every once in a while. Even Cliff cracks us up from time to time with his vids. Good luck and let us know what account to sub to! I'll be first in line. (VFR2NV on the tube)
*Landon*
Janfrederik
#210
Post by Janfrederik »
I would love a video review series from you. I would personally like something serious and in depth, but humor would be welcome as well. That being said, I think you should keep it to where if I wanted to watch a video of yours, I wouldn't have to go sifting through the parts that are humor, and the parts that are actual review.
Water babies singing in a lily-pool delight
Blue powder monkies praying in the dead of night
Here comes the black queen, poking in the pile
Fie-fo the black queen, marching single file
DeathBySnooSnoo
#211
Post by DeathBySnooSnoo »
I think that if you can get in all the relevant information. Plus have little bits of humor then they will be fun vids to watch.
On the hunt for...
gbelleh
#212
Post by gbelleh »
Yeah. Information and clear, well lit video would be the focus. Cutaways would normally be just a few seconds each, just to punch it up and break up the monotony. We'll see how it goes.
:bug-red-white
Syncharmony
#213
Post by Syncharmony »
This sounds great!
Keeping videos between 5-10 minutes would be a good idea. The 20+ minute reviews out there are always long winded and tend to stray off-topic.
Humor is great, politics are not. I really dislike videos that start going into the reviewers personal thoughts on religion, the government, forum drama, etc and so forth.
Current EDC rotation: Southard, Paramilitary 2, Sage 1, G10 DF2, Techno
On deck: Military, Caly 3.5, Air
Wish List: M4 Military, S90V PM2, Superblue Caly 3.5, G-10 Jester
3rdGenRigger
#214
Post by 3rdGenRigger »
If they're even half as good as your write ups are they'll be great. And I enjoy the odd little joke in a YouTube knife review...I've seen a couple that made me audibly chuckle despite it being late and my attempts to keep quiet.
All Glory To The Hypno-Toad
---> Branden
DeathBySnooSnoo
#215
gbelleh wrote:Yeah. Information and clear, well lit video would be the focus. Cutaways would normally be just a few seconds each, just to punch it up and break up the monotony. We'll see how it goes.
Sounds great! Looking forward to the first one...
On the hunt for...
DougC-3
#216
Post by DougC-3 »
This is great news! It's so hard to find decent YouTube reviews. I pretty much agree with the suggestions already made. I think a little humor can be great as long as it doesn't take up much time.
We can already tell from your reviews in this thread that none of the usual YouTube annoyances will apply. So many are done by adolescents who don't really plan what they're going to say beforehand, think it's cool for their hands to look like they just did a grease job on their car, think we want to know what they did that day, try to make it take as long as possible, and nervously drum their fingers on the knife while trying to decide what to say.
Then there's the more professional, narcissistic type who are trying to establish their YouTube persona and promote themselves more than inform the watcher.
I think the above Nilakka video by egdeobserver is a good example of an excellent, highly informative, business-like review. However, it's a pretty formal and impersonal, and I think could be improved by some humor or something to make it less impersonal.
We'll be looking forward to these and I'm sure lots of forumites will be trying to fine-tune them for you :D
zunedog31
#217
Post by zunedog31 »
Can't wait for the Youtube channel! Commenting here to remember to check back.
Own or have owned: Manix2, Dragonfly G10, Sage 1, Tasman Salt, Delica 4 waved, Kiwi, SS Police, Orange PM2, Pacific Salt, Gayle Bradley, Tenacious, Harpy, Military, Salsa, ZDP-189 Ladybug
Come chat with us on IRC at #Spyderco!
http://www.spyderco.com/forums/showthread.php?
DougC-3
#218
Post by DougC-3 »
In retrospect I'm afraid all our nit-pickyness is a deterrent to your creativity. Please disregard everything we said if you haven't already and proceed at will in all directions :) .
I don't care if you have 15 minute interludes with Curly, Moe, & Larry (the Three Stooges), or, better yet, Groucho, Harpo, Chico, Gummo, and Zeppo :D .
As my basic training drill sergeant said (after ordering everybody to crawl under the barracks and be standing at attention on the other side with a piece of policed-up paper or cigarette butt in hand, by the time he could run around there and blow his whistle): "If you take all the fun out of it, there ain't any fun in it."
gbelleh
#219
Post by gbelleh »
Thanks again for all the comments. Production is underway. I finally found a camera and lighting setup that I'm happy with, and I had to work out some audio issues. Right now I only have a couple hours a day to work on this stuff, but I'm hoping to start posting videos within a week or so.
:bug-red-white
gbelleh
#220
Post by gbelleh »
Still working on it as I find time. I'm a bit of a perfectionist when it comes to this sort of thing (I used to work in production). I wasn't happy with the video or audio quality I was getting, so after several tests, I ended up switching cameras and getting a new lighting setup. Now I'm determining which editing software I want to use, best settings, etc. Hoping to get one finished this week.
Also, still debating how much silliness I really want to have in these. Some of the stuff might be a little too stupid to make the final cut! If only I had an entire production crew, producers, writers, etc.
:bug-red-white
