How to Dull SS Pocket Clip?
MatthewSB
Post by MatthewSB »
How would you go about dulling the shiny SS pocket clip that comes on a satin bladed Para2 or Native5?
I'm thinking about using a scotchbrite pad to rough it up a bit so it matches the luster of the blade and other parts.
Thoughts?
You can stone wash it or acid etch it to completely remove the shine. I prefer a dull non reflective clip, and you can use ferric chloride to turn it a flat gray color. Then normal wear with give it a cool worn natural stonewash finish.
MatthewSB
Post by MatthewSB »
Evil D wrote:You can stone wash it or acid etch it to completely remove the shine. I prefer a dull non reflective clip, and you can use ferric chloride to turn it a flat gray color. Then normal wear with give it a cool worn natural stonewash finish.
What would make it closest to the finish of the S30V satin blade?
MatthewSB wrote:What would make it closest to the finish of the S30V satin blade?
Probably just get a rough scotcgbrite pad and rub it up and down in one direction. The finish on the blade is from grinding it so you just need to put a scratch pattern in the clip that's similar.
MatthewSB
Post by MatthewSB »
Thanks so much.
Will post a pic when done...
MatthewSB
Post by MatthewSB »
Scotchbrite pad worked great! Just went from side to side so it matched the pattern of the blade when closed.
Para2 next to a stock Yojimbo 2. You can see it's not nearly as reflective as the original polish.
xceptnl
Post by xceptnl »
Beautiful finish and a great modification that anyone can do. I would repost this on the "show your mods" thread as well.
*Landon*
ourgon
Post by ourgon »
My PM2
sand paper 1000 + hot oil wash
ourgon wrote:My PM2
I've heard of this but never tried it? Looks awesome.
Orion's Belt
Post by Orion's Belt »
ourgon wrote:My PM2
Any info on how that is done? Looks great.
-Ryan
edc solutions
Post by edc solutions »
Yes, what exactly is the hot oil wash other than awesome looking??
Coulro
Post by Coulro »
Also interested in the hot oil finish, it looks great! How durable is the finish?
If I'm not mistaken you just heat it up and dip it in oil.
