Show your mods!
SpyderScout
#1121
Post by SpyderScout »
RoBoTech wrote:I did read that, and realized you guys made your own material. Very nice.
It isn't what I thought it was.
Here is the material I THOUGHT you used.
http://www.knifekits.com/vcom/index.php?cPath=40_466
C-Tek.
The reason I asked about the Nancyl stuff was because some people have reported some brittleness in the C-Tek when working it down.
But, it looks good when finished properly.
I've never handled the C-Tek stuff, so have no experience with it.
I dont know, how their process or construction is either, but we have a carbon fiber backing.
We experienced no brittleness when working the scale material. Maybe the CF makes the block more stable to work with or maybe the brittleness is in other materials used.
Mere guesswork on my behalf, as we experienced no such problems.
(there were a hitch or two on the way, but no brittleness;-))
[SIGPIC][/SIGPIC]
RoBoTech
#1122
Post by RoBoTech »
SpyderScout wrote:I've never handled the C-Tek stuff, so have no experience with it.
I think the brittleness comes from the cells.
The cells are made by using aluminum "cages". Any time the cage is cut, the material left MAY become un-attached from the cut cage walls, so care has to be taken when working with it (cutting, shaping, sanding, etc). Once it it is finished, it seems to be stable.
The material you are making is completely different and should be stronger.
But, not everyone has the stuff or the time to make their own.
This makes your Pingo a one of a kind, unless you decide to make another.
That makes it more interesting, at least to me.
With production materials, any project can be duplicated. Just depends on whether anyone else wants to do it.
I am modding a Pingo just for the fun of it, and having something to do. But, your Pingo is unique, and it's very nice, indeed.
Good Job!
SpyderScout
#1123
RoBoTech wrote:I think the brittleness comes from the cells.
Good Job!
That makes sense. I suppose, thats where the problem could be; when a honeycomb 'cage' or compartment is cut in half and the Nanocyl exposed.
We experienced no such problems, as mentioned.
Yes, my Pingo is one-of-a-kind. Fun to make and fun to use/own.
Look forward to seeing the result of your Pingo modding.
Thanks for the kind words.
[SIGPIC][/SIGPIC]
einstein2001
#1124
Post by einstein2001 »
Blue G10 Tenacious dyed deep purple and acid etched using nail polish as resist.
Ladybug 3 Salt Hawkbill with a blue FRN dye job.
The attachment KfEC0J02.jpg is no longer available
Jazz
#1125
Post by Jazz »
Nice job, Einstein! Welcome to the forum. :)
- best wishes, Jazz.
Holland
Post by Holland »
einstein2001 wrote:Blue G10 Tenacious dyed deep purple and acid etched using nail polish as resist.
[ATTACH=CONFIG]21446[/ATTACH]
thats brilliant! great job
welcome to the forums
phillipsted
#1127
Post by phillipsted »
Nicely done, Einstein! Welcome to the forum!
TedP
Worry less - Breathe more...
Spydie Fanatic #185
Pockets
#1128
Post by Pockets »
Very nice! Welcome.
Delica PE, Dragonfly Salt SE, Stretch SE, Manbug SE, Mule 16, Sage 1, black/satin PM2, Native 5
einstein2001
#1129
Hey everybody, thanks for the welcome.
I just got into knives about a month ago and needless to say the spyder bit me pretty good.
You've got a great community here, glad I can join in.
RoBoTech
Pingo with thumbstud
#1130
Post by RoBoTech »
I did a quick job on this this morning and have not done a final finish. I may redo the clip side scale if I can't grind down a clip to fit what I milled. Sorry mill job, so I may just go with no clip and a kydex neck sheath, or order a 1/16" carbide end mill as a 1/8" is too large for the tight corners. Want that triangular shape on the clip, so may go that route and make a new scale.
Anyway, here is a Pingo with Toxic Green G-10 with black G-10 liners.
Put a new pivot in to allow use of the black "designer screws". Will order a set of SS instead, so that will be changed.
Also put on a thumb stud for easier one hand opening. Works very well.
A work in progress, but have too many other projects to finish up before getting back to this.
Holland
Post by Holland »
well done sir
Bladekeeper
#1132
Post by Bladekeeper »
RoBoTech wrote:I did a quick job on this this morning and have not done a final finish. I may redo the clip side scale if I can't grind down a clip to fit what I milled. Sorry mill job, so I may just go with no clip and a kydex neck sheath, or order a 1/16" carbide end mill as a 1/8" is too large for the tight corners. Want that triangular shape on the clip, so may go that route and make a new scale.
That has character nice job man .
Bob2swpa
#1133
Post by Bob2swpa »
Very nice
Spyderfly, Endura4 w Wave, C10PS Endura, Manix2, Centofante 3, Ocelot, Blue Domino, Yojimbo, Earthtone Paramilitary2,Vallotton sub hilt so far : :spyder:
Jazz
#1134
Post by Jazz »
Nice job, as always, RoBo.
FroOchie
#1135
Post by FroOchie »
This is my Manix XL I just got back from TuffThumbz. Carbon Fiber and Moonglow...
...I have no knives I keep in a safe but there are one or two that don't leave the house...
GTPowers
#1136
Post by GTPowers »
:eek: :eek: :eek: impressive!
Holland
Post by Holland »
very nice manix!
danracer
#1138
Post by danracer »
Ti pocket clip from usaknifemaker, fits nice and low on the pocket but my jeans have kind of a heavier fabric and the screws get snagged a little on the edge of the pocket.
vadel
#1139
Post by vadel »
Calypso Brown? No, this is Military Brown CTS-XHP. Custom pivot with flat head. Like pivot in Calypso...
My :spyder:s: C85G2 (EDC), C63GPS, C63GPS2, C63GP3, C65CFP, C65BKP, C65TIP, C143GP, C90PBLE, C90CFPE, C10PGRE, C10PGRE FFG, C10SGRE, C11PGRE, C10JBB, C11JBBP, C11JBOP, C113CFPD, C28PGRE2, C149GP, C135GP, C126GPFG, C36GPBNXHP, C36CFM390P, C81GGY20CP2, C46GGY, C79OR, C142GP, C122GP, C136G, C148G, C28T, LSS3T, C150GP, C95G2
Donut
#1140
Post by Donut »
I love the mods you do to militaries. Did you have to put that spacer under the clip to fit the screw?
-Brian
A distinguished lurker.
