Manix 2 lock problem
Hey guys, i got my manix 2 (G-10 stonewashed) and the lock is HARD to disengage and sticks alot, Would replacing the spring with a pen spring help? (I know it voids warranty) or should i let it wear in?
- xceptnl
I would let it wear in. I don't think a pen spring would be the alternative I would try if I was in a mood to tinker. Before you attempt to swap parts, maybe you should try to "slick-up" the ones you have. Try to polish the ball-bearing engagement area in the rear of the blade tang first. This can be accomplished without disassembly so that will keep your warranty in check.
Let it wear in.
My guess is that the spring is not likely the problem. Based on my experience, what you may be dealing with is friction between the G-10 scales and the polymer cage. As suggested, this should decrease overtime with use. You could to try using a dry lube where the cage interfaces the handle cut out to see if it improves.
I've had my Manix 2 for ~2 weeks. I don't have the friction problem but the spring is really frickin strong. So far no sign of lightening up. Certainly swapping the spring out with a spring from a pen is about the worst thing you could do. Disassembling and shortening the spring by a turn or two would be a saner thing to do. But don't do anything, I'm sure it will eventually settle in. And it's not like you can't operate the knife in the meantime, right?
All God's critters have knives.
Let it wear in.
My opinion is if you do anything to make it looser in a shorter period of time, the next thing that'll be an issue is that the lock engagement is too loose too soon.
Spyderco WTC #1044
“Those who cannot remember the past are condemned to repeat it.” George Santayana, The Life of Reason: The Phases of Human Progress, 1905 to 1906
NEVER FORGET!!!
NEVER FORGET!!!
- MisterJeff
It will likely always be a two finger knife to close, often a two handed closer. The spring is stiff and there is some initial friction.
You might be able to send it in for an adjustment. For me, I just deal with the nuances of that type of lock. Never had to quickly unlock and close a knife so it's a moot topic really.
