The "WHY" of the Bushing Pivot?
chuck_roxas45
Post by chuck_roxas45 »
I really liked the pivot system of the Para 1. Easy enough to tweak out blade play, if any.
And how smooth do you really need your knives to be?
No play trumps smoothness for me just as long as it's not excessively gritty. My millies are pretty darn smooth enough for me without having to contend with bladeplay.
DeathBySnooSnoo
Post by DeathBySnooSnoo »
chuck_roxas45 wrote:I really liked the pivot system of the Para 1. Easy enough to tweak out blade play, if any.
None of my Manix2s or Para2s have any play in them at all. No sorry...my standard production M2 has a tiny bit of side to side, but I also took that one apart so I don't think that really counts. And I could probably get rid of the play by messing with tightening each side bit by bit til it was perfect. And they just drop when the lock is released and I like that a lot.
On the hunt for...
Thanx much for all of the input. We're still chatting.
chuck_roxas45
DeathBySnooSnoo wrote:None of my Manix2s or Para2s have any play in them at all. No sorry...my standard production M2 has a tiny bit of side to side, but I also took that one apart so I don't think that really counts. And I could probably get rid of the play by messing with tightening each side bit by bit til it was perfect. And they just drop when the lock is released and I like that a lot.
I wonder how you'll feel if you have play that can't be tweaked away or if it can, I don't have the skills to do it. :D
I just try to ignore the play because of the awesome steels and luckily, I've been able to tweak out the play on my regular P2. So it's all good but it would nicer to have no play like on the P1 or the Millie.
No dissing Snoo but I've found that most people who do prefer the bushed pivot are the lucky ones who have specimens with no blade play.
DeathBySnooSnoo
chuck_roxas45 wrote:I wonder how you'll feel if you have play that can't be tweaked away or if it can, I don't have the skills to do it. :D
Well, I would probably be pretty pissed. But, I think that all it really takes is some patience. I just start by tightening each side a bit at a time past snug until both sides have been pretty much fully tightened down fully. I'm talking like maybe an 1/8 of a turn or less per side. It just seems to ensure that you don't get one pulling things off to the side just that little bit which would allow some play. As Sal has said, the tolerances are tight.
I think that the play would likely come from one screw bottoming out and not being able to be tightened that last little tweak that would properly snug everything up. I would use the method above to see if I would balance it out, or even use a bit of sandpaper to grind down the end of the screw just a tiny bit to see if you could tighten it down just that fraction more.
On the hunt for...
chuck_roxas45
DeathBySnooSnoo wrote:Well, I would probably be pretty pissed. But, I think that all it really takes is some patience. I just start by tightening each side a bit at a time past snug until both sides have been pretty much fully tightened down fully. I'm talking like maybe an 1/8 of a turn or less per side. It just seems to ensure that you don't get one pulling things off to the side just that little bit which would allow some play. As Sal has said, the tolerances are tight.
That's just it snoo, it may be doable on the P2 but on the non-bushed pivots, you hardly had to do any tweaking at all. I don't really like to tweak if at all possible but it is what it is. :)
DeathBySnooSnoo
chuck_roxas45 wrote:That's just it snoo, it may be doable on the P2 but on the non-bushed pivots, you hardly had to do any tweaking at all. I don't really like to tweak if at all possible but it is what it is. :)
Maybe. But I think that any knife with a screwed pivot is going to need adjusting at sometime. And I think that the smooth action and the freely moving blade are things that I am glad to trade for a little more fiddle-y adjustments when needed.
Of course there are probably lots of people that fall on either side of this, and that is ok. I would probably end up just as satisfied with a knife that had non bushed pivot, I just tend to prefer the bushed and where given a choice would gladly take them over the non bushed.
On the hunt for...
Splice
Post by Splice »
I personally love how ultra-smooth my pm2 is. I vote for keeping it.
Roundabout136
Post by Roundabout136 »
I vote to keep as well.
I don't think I gave my PM2 enough of a break in period. I got antsy and took it apart to see the insides and so forth. The engineer inside me.
Super smooth and fast. I seriously could flick this thing open all day.
Just a tiny tiny bit of wiggle side to side. Can't get it out, tried everything.
DLC PM2, FFG Delica, Wave, ESEE 4, Izula
dsmegst
Post by dsmegst »
I do appreciate the engineering behind the stepped pivots but in using various Spydies, I don't miss it. It's a testament to how good the standard pivots become when broken in. I prefer a bit of tightness on all my folders so I crank down on the stepped pivots to add just enough friction to not allow a complete free movement.
Dan (dsmegst)
:spyder:
:spyder:
TBob
Post by TBob »
Sal,
I have no complaints with Spyderco's implementation of any of the designs I own. I haven't "tweaked" any of them, just keep them clean and lubed. Thanks for the engineering that you put into your designs, and for listening to your community.
:spyder:: Advocate, Slysz Bowie Ti, Southard Black Blade, Stretch Carbon Fiber w/ZDP-189, Fluted Ti Native5, Terzuola Starmate, Terzuola SLIPIT, Leaf Storm, Gayle Bradley, Roadie, Chaparral CF, Chaparral Ti Stealth, Des Horn, Stretch FRN (Blue) ZDP-189, Centofante Memory, Military Black Blade CE, Delica4 FRN CE, Endura4 FRN Black Blade CE, Assist Orange FRN, Manbug ZDP-189, Ladybug 3 FRN SE, Delica4 Blue NLEOMF, Moran Drop Point BB, et al. :spyder: Spydie Fanatic #179 :spyder:
As far as compression locks go, i just need it smooth enough to drop by gravity so i can press the lock and drop the blade shut. If that one detail is lost, i won't buy another compression lock equipped knife. That's the sole reason i prefer this lock over any other (except of course the CBBL).
dsmegst
#33
Post by dsmegst »
I've had a few Manix 2s (early examples right after the introduction of the stepped pivot) that I had to modify to get them to my liking. The recent ones have been much improved when it comes to side to side play and have tighter tolerances.
Dan (dsmegst)
:spyder:
:spyder:
phaust
#34
Post by phaust »
Splice wrote:I personally love how ultra-smooth my pm2 is. I vote for keeping it.
The stepped pivot doesn't make it smoother.
nullity
#35
Post by nullity »
I love pivot bushings... in theory.
If the bushing is perfectly toleranced, I love it.
If the tolerances aren't perfect, I'd rather have the user adjustability to fix it.
I use the word "perfectly" somewhat in jest, because what is too tight or too loose is subjective, and I can imagine that is a nightmare for a manufacturer.
dialex
Post by dialex »
It's complicated. On mass production knives, setting those tight tollerances is really a pain.
phillipsted
#37
Post by phillipsted »
Just a note on the pinned construction. I have always loved the Wayne Goddard collaborations and have most of the variations Spyderco made. On the micarta models, with no liner, the micarta isn't as stable as FRN or G-10 and has caused two of my Goddards to become excessively tight. I sent my Junior in to be adjusted by SFO, but they were not able to give it back its nimble opening. That's the sacrifice you make with pinned pivots...
For me, I love the smooth opening of the Para2. It is simply a joy to use.
TedP
#38
Hi Ted,
We have noticed that micarta moves, pinned or screwed doesn't seem to matter. First learned about this from Phil Bogezewski 20 years ago. We ended up adding liners where we use micarta. Also micarta doesn't hold clip screws well, so the liners also offer a more secure fastening for clip screws.
ruggedscotsman
#39
Post by ruggedscotsman »
David Lowry wrote:Just my $.02
I don't care for the bushed/stepped pivot on the Manix 2, Yojimbo 2, and Para 2.
I like my knives to be a bit tighter and I cannot tighten them down to the point that I usually like.
It's a very small gripe but I would just like to throw it in the hat with the rest.
Some of the longest lasting knives I own are pinned and they still have no play.
I think I have to agree...
I've had a pinned calypso jr ss for many years, and there is still zero play in any direction. In fact, I always thought it was a point of pride that spyderco design/build quality was so good, it made bushings/washers unnecessary.
I was looking very hard at the gayle bradley, but can't get past this (among a few others) feature. Seems to me that it would reduce lateral rigidity, and potentially increased wear/slack over time.
I used to be a big supporter of pinned knives because my one long time user pinned knife had never developed any play, but that recently ended. My Centofante 4 has finally developed a little side to side play after recently rotating it with my Yojimbo 2. It isn't a lot, and like my Para 2 and Yo 2, you would have to know what to look for to even know it's there, but if you know how to test for it you can definitely feel it.
So, 4 months after this thread, i have to come to the conclusion that i do prefer having the bushing. I've gone back and played with my Para 1 a bit, and i just can not find a sweet spot in that pivot where the blade will drop as smooth as my Para 2 without having at least as much play as the Para 2 has. The only non bushing knife i can easily compare it to is my Military, which i can adjust so there's no play (or at least so little that it's irrelevant) and the blade will fall shut with gravity, but then that blade is much larger and heavier than a Para 1 blade too. The lock and detent action also feel much better IMO on the Para 2 than the Para 1. Like all things though, your mileage my vary.
