Techno lock up not so solid?
kiwispyder
Hi, have had the Techno for a week or so now and really loving it.
I have noticed that if I apply pressure with my hands (as if I was trying to close it without disengaging the lock bar) the lock bar moves out about a millimeter or slightly less, then when I take pressure off it moves back in.
This is my first RIL, is it normal to have a "small" amount of movement
in the lock bar?
Thank for your feedback.
in the lock bar?
One of the designs features of the RIL is that if you grip it really tight, the lock bar moves inward (which should make it harder to disengage under exfra pressure from "hard use") some movement is not uncommon even on Sebenzas. Is there any blade play? There shouldn't be. Sometimes it just requires a little tweaking of the pivot screws. Hope that helps :)
Love my techno, it's a sweet little knife!
kiwispyder
Hey thanks for the reply, there is some blade play up and down due to the lock bar moving, but barely perceivable and only when I'm trying to move it, not when I'm holding the knife tightly. It doesn't bother me.
The gripe I have is the wire pocket clip, the back corner of it really digs in badly when gripping the knife and cutting hard.
I wish it came with the original clip as the prototype. I may put my own clip on to it later, wonder how hard the scales are to drill and tap?
Otherwise I love the knife.
- Brock O Lee
Does the blade have any side-to-side play?
I once had a liner-lock where the lockbar would move when I did the same as what you described. It turned out that the blade also had some side-to-side play. Once I tightened the pivot properly (with some locktite to keep it tight), lockup was solid.
kiwispyder
- Brock O Lee
kiwispyder
aidansdaddy17
Hmm...I just bought one. I know either way, Spyderco will take care of us if this becomes an issue overall. I saw a video on this on youtube already! Sal, care to interject? Hopefully when mine arrives I will not have an issue. Still is a beautiful knife. Thanks to Spyderco for seeing that in this model before others. Being able to bring it to us for purchase.
- Minibear453
Contacting spyderco would probably be best. However, I read a knife making book by someone, I believe Bob Terzuola, and he wrote that the liner lock should only contact the blade at the bottom 1/8" of the knife, to prevent blade rock.kiwispyder wrote:
Should the whole lock faces be touching from top to bottom?
Mine has a very small contact point.
I'll contact Spyderco about it an see what they reckon.
Thanks again.
Carry a sharp knife, and life will never be dull
kiwispyder
I tried calling Spyderco warranty today but no one was there, I'll try again tomorrow.
I'm uploading a video at the moment of the blade rock which I will post soon so you can see what I mean.
No major, I will talk to Spyderco tomorrow and If they say send it in I will, Just can't imagine life without this knife in my life..lol, probably take a fair few weeks to get back as I live in New Zealand.
kiwispyder
This is what I'm talking about...
<iframe width="853" height="480" src="http://www.youtube.com/embed/iOKM4_yrEjE?rel=0" frameborder="0" allowfullscreen></iframe>
- Minibear453
