Manix2 154CM or CPM-S30V?
I am thinking of picking up a Manix2 Black Blade and I don't know which steel they are made from.
The Manix2 I have is 154CM, and the print Catalog I got from Spyderco this week says they are CPM-S30V, then the website says 154CM????
If the Manix2 DLC is CPM-S30V I will probably go up an buy one this weekend.
Cameron
Cameron
Bradley Folder 2 CPM M4
Military CTS XHP - CPM Cru-wear
Para Military 2 CTS XHP - CTS 204P
Manix 2 CTS XHP - CPM Cru-wear - CPM M4
Fred Sanford
There will be a rolling change if I am correct. I think that the price or each is so close now that they will be moving to CPM-S30V. Eventually all the Manix 2's will have CPM-S30V. I have some of the 154CM models and they are just awesome. I don't think that people give enough credit to 154CM. Good steel.
Peace!
Peace!
I also agree. 100%dgulbra wrote:I agree, 154cm is such an under rated steel. I have a few fixed blade with 154 and they perform outstanding. I think the only advantage on the S30v Manix 2 is that it will be full flat ground.
I find that 154CM is one of the easiest steels to sharpen if you need to do it yourself.
Spyderco please make a wire clip version of the Manbug/Ladybug!
DeathBySnooSnoo
- chuck_roxas45
I really like the edge that 154CM takes.
Full flat ground? When was that announced? To my knowledge it will remain a hollow grind (thank goodness). A bit of variety. I like my manix in 154 CM. A search for Longish term review DLC Manix should pop up my review I did and it has been a real workhorse.dgulbra wrote:I agree, 154cm is such an under rated steel. I have a few fixed blade with 154 and they perform outstanding. I think the only advantage on the S30v Manix 2 is that it will be full flat ground.
- The Mastiff
Yeah, I'm with Chuck on this. I like it, and CPM 154 better than I like S30V, which is high praise. I do like S30V very much. I mean for stainless steels of course..... :)I really like the edge that 154CM takes.
Joe
Joe, I am sure it was just a typo but 154CM is the ingot version and CPM154 is the particle/powder version.The Mastiff wrote:Yeah, I'm with Chuck on this. I like it, and CPM 154 better than I like S30V, which is high praise. I do like S30V very much. I mean for stainless steels of course..... :)
Joe
If it was CPM 154 I doubt we would see a change as it is a fantastic all around steel for user and maker with a high obtainable hardness and fine micro structure. I have used the similar powder version RWL-34 for some time and it can take a high polish as well as a toothy edge and hold it well.
According to Crucible data 154CM and CPM 154 have the same wear resistance, however with the advantage of the particle process and finer carbide structure the particle version can take a much finer edge and resist chipping or rolling (I believe this is an increase in strength if I remember my metallurgical terms correct).
I am still waiting for Spyderco to do something with CPM 154 or RWL-34....it is a dream that seems will stay but a dream.
154 CM is a pretty good all round steel, I do find that S30V holds a useble edge a bit longer for me (my use, my sharpening) but 154 takes an edge easier. Pretty much a toss-up where I am concerned.
I am hoping for some sales on the 154 models so I can pick up a CE to go with my PE. If not, I may look at the new lightweight in CE to try out the BD1. I am not a "steel snob" as the value of most supersteels are lost on me but I do like trying new stuff out.
A 154 CM Manix pretty much blows away anything I even dreampt of having or using when I was younger.
peacekeeper
Agree completely. I find S30V a bit hard to sharpen but 154 is easy and they perform about the same.dgulbra wrote:I agree, 154cm is such an under rated steel. I have a few fixed blade with 154 and they perform outstanding. I think the only advantage on the S30v Manix 2 is that it will be full flat ground.
Own or have owned: Manix2, Dragonfly G10, Sage 1, Tasman Salt, Delica 4 waved, Kiwi, SS Police, Orange PM2, Pacific Salt, Gayle Bradley, Tenacious, Harpy, Military, Salsa, ZDP-189 Ladybug
Come chat with us on IRC at #Spyderco!
http://www.spyderco.com/forums/showthread.php?
Yes, please, more hollow-grinds done right. :DZenith wrote:Full flat ground? When was that announced? To my knowledge it will remain a hollow grind (thank goodness). A bit of variety. I like my manix in 154 CM. A search for Longish term review DLC Manix should pop up my review I did and it has been a real workhorse.
DeathBySnooSnoo
Both are excellent materials. 154 CM is an ingot material, very similar to VG-10. S30V uses a powder metallugy process to process.. Both hold a good edge well, S30V edge lasts longer, but 154CM keeps a super fine edge just a bit longer and is easier to sharpen. This is from what I've read
I need more play to go further
Charlie
