Show Your Wood Scale Mods!
3-1-1
Post by 3-1-1 »
I have often wondered why more people don't post mods using wood. Either they are shy or not many are doing it. But I have been seeing an increase lately, so here is a spot to do it.
I love a wood scale. To me the stock G10 or FRN is just a pattern that I'll throw out later. To get things started I thought I'd share some pics of a complete set of value folders I'm working on right now. Still got to put the clip on the Reslience and have not yet decided what wood to go with on the persistence (not pictured). Contemplating a yellowheart wood.
[ATTACH]20418[/ATTACH][ATTACH]20419[/ATTACH][ATTACH]20420[/ATTACH][ATTACH]20421[/ATTACH]
Post by 3-1-1 »
Forgive the blade scratches, i actually had been using these before customizing. Might have to get some new shiny ones to move the scales to....
phillipsted
Post by phillipsted »
There are lots of interesting custom wood scales over on the "Show your Mule" thread!
TedP
3-1-1 wrote:I have often wondered why more people don't post mods using wood. Either they are shy or not many are doing it. But I have been seeing an increase lately, so here is a spot to do it.
I like the lighter colored wood. I mentioned using cedar to someone a while back but they weren't sure if it would hold up or not. I was shopping the other day and saw these blank slabs of cedar used to hang in closets, and thought they'd be the perfect size to make small scales out of. I think it would be a cool wood to use as inlays on something like a Kopa or Kiwi.
WMR
Some More wood scales
Post by WMR »
Spydie Mods 01b.jpg (70.0 KB)
3-1-1
Post by 3-1-1 »
WMR....
Jealous of that leafstorm, what do you have going on there?
WMR
Post by WMR »
3-1-1,
That is Amboyna Burl. If you look closely at your Rolls Royce dashboard, you will see that it is made from the same wood.
Douglas
Post by Douglas »
I just ran out to check, and yes that is definitely the same wood as the dashboard on my Rolls. :p
Not quite so exotic a material on my wood scale mod:
C.L.L 97
Post by C.L.L 97 »
WMR wrote:Spydie Mods 01b.jpg (70.0 KB)
WMR those scales are awesome, I really like the look of the leafstorm and the micheal walkers!
Caden's :spyder:'s-g10 dragonfly, digicamo para2,bug,honeybee,sharpmaker.
Newest :spyder: manix 2 lightweight.
:spyder: top wishlist: junior,D4,E4,,h1 D'fly salt,h1 ladybug salt,g10 manbug,caly3•3.5,all sprint para2's
Have to have= brad southard flipper, gayle bradley:spyder:
"combat knife is actually 10% weapon and 90% tool".~ Al Mar
WMR
Post by WMR »
Thanks guys.
Douglas, That is beautiful workmanship! I bet your Rolls doesn't look that nice.
OldSarSwmr
Post by OldSarSwmr »
You guys are really knocking them out of the park! Those scales look great.
:spyder:
Dan
DCDesigns
Post by DCDesigns »
What FRN model could you possibly replace the scales on without working for HOURS milling out wood for the inset liners? Ive only seen a delica with wood grips once... G10 liner lock models are definately by far the easiest to make scales for, frn knives the hardest. Ive made scales for a g10 dragonfly, and im considering making some ironwood burl scales for my GB. Not sure yet, we will have to see what happens!
3-1-1
Post by 3-1-1 »
i don't know of any easy frn replacement jobs. replacing the frn is a lot of delicate work with a flat router dremel bit for sure on all models i have opened up, but it can be done.
i am plannng on doing a tasman that way soon assuming I find what I expect to inside. would have started but the yellow frn h1 salt model i bought has rivets instead of screws. going to have to either drill them out and replace or buy the black model which appears to actually have some torx screws. my plan is actually to create a karambit style out of it with the finger hole.
cougar337
Post by cougar337 »
These are all my wood handled knives but these were done by various people
Redwood Lace
Spalted Maple
Koa
Cocobolo
- Ian
Post by The Deacon »
Not my work, but my knives, and most were commissioned by me...
[CENTER]Image[/CENTER]
Top row, left to right: Waterfall Oak, Red Palm, Curly Koa, Desert Ironwood
Bottom row: "Earthling", Birdseye Maple, "Wooden Eagle", Lignum Vitae (Verawood), "Tequila Sunrise Earthling"
The first three in the top row were done for me by Tonydahose, the Desert Ironwood, and all the knifes in the bottom row, by Santa Fe Stoneworks.
Left to right:
Kopa in Purpleheart by Tonydahose
Native V in Mexican Ebony by Gull Wing
Stretch in Lignum Vitae (Verawood), R2 in Curly Koa, Atlantic Salt in Birdseye Maple, all by Steve Rice (STR)
Schempp Persian in Desert Ironwood by Dirk Potgieter
C.L.L 97
Post by C.L.L 97 »
Those are great looking scales Deacon!
@ DcDesigns do you have pictures of the dragonfly that you made scales for... On the thread that you made about it, it was never finished, I think you were doing zebrawood?
Stew
Post by Stew »
Wood on a spydie transforms thje look of it so much. I suspect that we see less because synthetics are more readily available in slim pieces already?
I have just picked up a kiwi slipit in stag that I'm going to replace the staq on - debating between synthetic or wood - all the pics here are making me think wood!! (i think I have some thin cut desert ironwood that could fit)
Cheers,
Stew.
[CENTER]www.StewartJLight-Knives.com[/CENTER]
haarspalter
Post by haarspalter »
hey Guys,
i was wondering what tools you use?
i was thinking about getting a dremel and some sanding paper.... should that do the job?
thanx in advance
andy
:spyder: Mule k390-S110v-Cruwear, Gayle Bradley, Cruwear Military Collectors #13V, CPM-M4-Ti Military CF Scales, Para2 20cp
3-1-1
Post by 3-1-1 »
Depends on the size of the wood you are starting with, and what model of knife you are going to scale. If just doing a fairly simple g10 replacement (full metal liners), and using small, pre-cut knife scale blanks from one of the standard suppliers, I'd say a dremel, sanding paper, a good drill and some bradford bits should be enough. Get some polishing compound to shine it up at the end too, if you want some shine.
phillipsted
Deacon - I really enjoyed the photos of your Lignum Vitae retrofits. I'm putting the final touches on a ZDP-189 Mule in that wood now. What a great material to work with - tight grain, tough as nails, and pretty grain. It is also so oily that you don't need to put any finish on it. Love it. I'll post pics in the Mule pic thread later in the week.
TedP
