Different methods to sharpen your knives
BigBill5953
Post by BigBill5953 »
Alright so I know you can use a *sharpmaker or lansky system to sharpen *your knives but*I've read on bladeforums that people use the bottom off a coffee mug to sharpen their Case CV knives. I have chestnut CV peanut in the mail right now, and when the time comes to sharpen it, I'll have to give the coffee mug a try.*
My question to you Spydie fans is this: what different and unconventional ways do you sharpen your knives? They can be any knife brand, Spydie or not*And if you dont use unconventional ways, what system do you use?*
-Billy
Centofante 3|Brown FFG Delica 4|Persistence|Sharpmaker & UF rods|SS Kiwi|Manbug SE|Blue UKPK SE Leaf|Calypso Jr. FRN|Blue Dodo SE|Centofante 3|Grasshopper|Tan Ladybug Salt|Rookie Sprint|
bammann45 wrote:In Los Angeles we have roaming packs of carnivorous tortoises. I am glad we finally have a folder that can punch through their shells.
sharpguitarist
Post by sharpguitarist »
Hey billy,
I've used a coffee mug to sharpen my knives before. In a pinch, if you have no other options, it will touch up an edge quite well.
Just make sure there are no chips in the mugs bottom.
I also carry a couple of credit card sized peices of fine grit (600 & 800) sandpaper in my wallet just in case i have no other way of putting an edge on one of my edc's.
One other thing i've done is use the top edge of my truck's door window to hone the knife i'm carrying.
I have diamond rod sharpeners in each one of my edc bags, and another in the pouch i carry my leatherman in at work. It gets borrowed almost every day by one of my co-workers.
Later,
Don
dbcad
Post by dbcad »
Anything that is smooth and harder than the blade material can be used to enhance an edge.
Currently trying out this old ballast from some kind of industrial lamp. It seems to do a pretty good job touching up. A few folks from work swear by them. Bottom line is always making the edges on both sides meet in the middle with as much precision as you can muster :)
Exploring edges can be great fun :D
Charlie
chuck_roxas45
Post by chuck_roxas45 »
Yup, I've used a coffee mug to sharpen friend's knives because it was the only thing available when they showed me their knives. They were pretty surprised at the results though to speak truth, they were still pretty much dull by knife nut standards.
C.L.L 97
Post by C.L.L 97 »
Don't know if this would work or not, but I've seen people sharpen knives on concrete blocks, and edges of car windows like Don said.
Caden's :spyder:'s-g10 dragonfly, digicamo para2,bug,honeybee,sharpmaker.
Newest :spyder: manix 2 lightweight.
:spyder: top wishlist: junior,D4,E4,,h1 D'fly salt,h1 ladybug salt,g10 manbug,caly3•3.5,all sprint para2's
Have to have= brad southard flipper, gayle bradley:spyder:
"combat knife is actually 10% weapon and 90% tool".~ Al Mar
BigBill5953
C.L.L 97 wrote:Don't know if this would work or not, but I've seen people sharpen knives on concrete blocks, and edges of car windows like Don said.
I've heard about using a concrete block before. Might have to try the top of my truck window just to see.
-Billy
razorsharp
Post by razorsharp »
I can get shaving on a brick., and have git shaving edges on plates, cups, bowls, crock pots, mortars and pestles, sandpaper.
Put paper cutting edges on knives with concrete and cinderblocks
I. Used a car window at one stage and a rock
Cant think of anything elsev
w3tnz
Post by w3tnz »
In soviet russia, knife sharpens you.
tonydahose
Post by tonydahose »
paper wheels for me
WTC #1444 Always Remember
My knives
Spydie count: a few:D
xceptnl
Post by xceptnl »
BigBill5953 wrote:...Might have to try the top of my truck window just to see.
It works really well, very similar to the fine texture profile stone on the radiused edge. I have not had to sharpen it from dull before, but have reapplied a hair popping edge before with light strokes.
*Landon*
I'm so hard i just use the back of my left arm.
Don't forget you can also use the top of the water tank on a toilet if you take the lid off...nice smooth porcelain.
BigBill5953
xceptnl wrote:It works really well, very similar to the fine texture profile stone on the radiused edge. I have not had to sharpen it from dull before, but have reapplied a hair popping edge before with light strokes.
Sounds good. How exactly did you sharpen/ touch it up? Which way did you position the blade? Which way did you move it? (edge first or spine first)? I'm pretty unsure of and kind of freehand sharpening. I have the sharpmaker but Im looking at getting the Double Stuff sometime in the near future.
-Billy
Dr. Snubnose
Post by Dr. Snubnose »
I have sharpened a dull field knife (no edge) on a cinder block, removed burrs with a straight stroke on the corners of a wood 2 by 4 and then went to a red construction builders brick for a field sharp knife and finished on a leather strop loaded wit 0.5 micron diamond paste and had an edge that made hair pop off my arm. FWIW that took about 12 minutes to do and I travel daily with a lot of sharpening equipment, sharpmaker, diamond stones, Japanese Whetstones, strops etc etc......Doc :)
razorsharp
Dr. Snubnose wrote:I have sharpened a dull field knife (no edge) on a cinder block, went to a red construction builders brick and finished on a leather strop loaded wit 0.5 micron diamond paste and had an edge that made hair pop off my hair. FWIW I travel daily with a lot of sharpening equipment, sharpmaker, diamond stones, Japanese Whetstones, strops etc etc......Doc :)
Hair pop off your hair eh?
Dr. Snubnose
razorsharp wrote:Hair pop off your hair eh?
yah I have hairy arms.....well use to....oh my typo.......lol.......
Rwb1500
Post by Rwb1500 »
I use the curb and strop with cigarette butts. With all these knives who can afford sharpening gear? :D
tikkidaddy
Location: marietta sc...but im not sure if its on earth though!!
Post by tikkidaddy »
i have used coffee mugs, glasses etc id luv 2 get one of those lamp ballast thingamabobs my grandad had one. He also had a ceramic rod that was coated w/ some kinda hard slick blue glass, he used it working as an electrician. That thing was as smooth as window glass and good God have mercy, that old man could "edge 1 up". Ive used semichrome on leather. Ive used the steel in the canadian crutches I built. Look around. Youll find something
"I hate the thought of killing anything, its the last thing I would advise, but as a matter of survival, all creatures are fair game."-- Les Stroud.
I wonder if spyders feel that way too??--mark.
razorsharp
defenestrate
Post by defenestrate »
For bigger, rougher blades like axes or cheap machetes, I have had good results with bricks and sometimes field/river stone.
