I love my Spyderco Gayle Bradley, but...
eneyman
Post by eneyman »
put pressure on lower down right below that jimping on the bar. my gb also loosened up after a few days of opening/closing.
DeathBySnooSnoo
Post by DeathBySnooSnoo »
Mine is smooth and as easy to unlock as a slipjpint...ha ha. But seriously it really is. I can use the knife with both hands equally as easily and smoothly. The lock has good tension on it. It takes a bit of push but nothing that digs into my thumb. And the lock up has just got to the point where the side of the lock bar is flush with the tang of the knife.
Now it is my EDC knife and it has been used quite a lot so is well worn in, but it really wasn't any stiffer or more difficult to disengage when I got it.
On the hunt for...
jackknifeh
Post by jackknifeh »
I have mine in my hand. I went to get it because like most knives I just close them but when it's not in my hand I don't remember exactly how. So, I'm holding the knife like I'm cutting. I rotate it around so the thumb is on top of the lock and the end of my index finger is on the jimping on the spine at the same time. I push the lock over and while holding it I push the blade closing it. It stops at a 90 degree angle with the handle because the choil in the tang hits the end of my thumb which is still holding the lock bar over. Then I move my thumb to the spine and finish closing the knife. Of course there are two actions for the first part of closing the knife. Push lock bar over and push the blade closed but they are both done so it looks like one motion. Then the third motion is putting the thumb on the spine to finish closing. Very simple, fast and no problem at all.
Jack
gull wing
Post by gull wing »
I love my GB as well, but unlocking WAS a prob, I reworked it :D . Do a search. There are lots of other post's.
SCARAMOUCHE! :bug-red-white
Fat Goat Forge
Post by Fat Goat Forge »
gull wing wrote:I love my GB as well, but unlocking WAS a prob, I reworked it :D . Do a search. There are lots of other post's.
Took me about 5 minutes with my dremel tool and the small drum sander attachment to rework the liner and scale to allow full access to the spyderhole and the liner lock.
Makes a world of difference. Now its easy to open and close.
George Spear
Fat Goat Forge
Master Farrier (horseshoer)
Apprentice Knifemaker
My Spyderco's: Delica Orange 4 FFG, Gayle Bradley C134CF CMP-M4, UKPK Maroon Drop Point FRN CTS-BD1, Dragonfly 2 ZDP-189.
On Order: Caly 3 Super Blue
Zenith
Post by Zenith »
Fat Goat Forge wrote:Took me about 5 minutes with my dremel tool and the small drum sander attachment to rework the liner and scale to allow full access to the spyderhole and the liner lock.
I guess I don't understand why, though I do know it is personal taste, but I can access the hole with thick welding gloves I use on site.
Unlocking is not that easy as the Military with gloves, but that was how it was designed if I am not mistaken, and I prefer that.
DeathBySnooSnoo
Zenith wrote:I guess I don't understand why
+1
On the hunt for...
Sht
Post by Sht »
rodloos wrote:I saw some comments about the difficulty unlocking some people had before I bought it, so I was aware of the issue. It hasn't really been an issue for me, perhaps because I have fat thumbs :D . I just put my thumb pushing down on the lock, then I push over to the left (if that makes sense). Everyone's hands are different so it may be a different feel for others. I happened to be carrying my Bradley today, opening/closing it during my drive into work :) .
I'm glad to hear I'm not the only one that plays with knives while at the wheel
Gayle Bradley
Bob lum tanto sprint
Milie camo
Para2 camo
Manix2 moonglow
Tasman salt
Tenacious (the whole lineup)
Kiwi SS
Knives at all times
gull wing
Post by gull wing »
I don't know if I can cause you to understand, but I will attempt.
Look at a Sage I or II. See the generous scallop opposite the locking lug so as to easilly access the lock lug. This is what I have become accustomed to in a liner/framelock. Spyderco has spoiled me.
http://www.bladeforums.com/forums/showt ... light=Sage
Orlando De Free
Post by Orlando De Free »
Some knives like the Gayle Bradley are built to be used hard for a long time. Often the mechanism needs breaking in to provide one's desired ease of unlocking. Your new Gayle Bradley must be such an example.
Break it in. It will get better.
Orlando
If you didn't get my dirty joke it's because you have no sense of humus - Mom De Free
:spyder: Currently own
Ladybug 3 se, Assist, Ladybug se w/photon, Techno, Rubicon, Manbug ZDP, Dice
Blerv
Post by Blerv »
You get screaming from both camps.
"It's too hard to disengage quickly" (as if that is ever a concern)
"It's too easy to disengage when I'm twisting or if I need to defend myself" (that happens all the time)
The GB's philosophy makes perfect sense assuming its intended use. Gayle seems a man's man, like Eastwood who uses Jack Daniels for aftershave.
"Go ahead, close my knife."
DeathBySnooSnoo
#32
Blerv wrote:You get screaming from both camps.
+1
On the hunt for...
DeathBySnooSnoo
#33
+1
You ain't a man until you have an unmodded GB :p :p :p :D :D :D
On the hunt for...
Sonny
#34
Post by Sonny »
Papa_K wrote: One thing that I wondered about when I first got the knife was how the liner doesn't slide completely behind the blade. I've been a GB owner for a couple weeks now, and for me it's a keeper.
That's part of the design; a good thing. It allows you to use this knife for yrs of wear and then the liner will move (wear) more to the right. Your kids might see it move.
I don't have GB, but jackknifeh keeps raving about his, so I might have to get one. I do have a Manix2 in M4 which is sorta similar; an excellent knife for heavy-duty use.
Sonny
Blerv
#35
Post by Blerv »
DeathBySnooSnoo wrote:+1
Haha!
Yea mod vs no-mod not a big deal to me. I understand the logic tho. Kinda like when Schempp skips jimping; when analyzed in context the philosophy holds weight.
gull wing
#36
Post by gull wing »
So it wasn't an "understanding" you were seeking, it was a condemnation. "you ain't a man till"
I've seen very mild appearing men do quite amazing things under great stress. (Vietnam vet) :(
jackknifeh
#37
I guess the answer is too simple. Buy two GBs and have one modified to allow easier access to the lock. I say yes. Wallet says :eek: .
Jack
Blerv
#38
Post by Blerv »
gull wing wrote:So it wasn't an "understanding" you were seeking, it was a condemnation. "you ain't a man till"
No intention to go there at all. Sorry if it sounded as such.
Just trying to read GB with an Eastwood reference. Totally whimsical.
JNewell
#39
Post by JNewell »
Listen up, friends. :) No one knife is going to be all things to all people. Think Sebenzas...some people swear by the regular (more GB-like), others by the Classic/21 style (more Sage/Military like). Both are good...buy the one that suits you...don't worry about what the other guy prefers... :spyder:
Blerv
#40
Post by Blerv »
Exactly! I think both camps should feel free for a little jovial teasing.
Ive been ragging on Camaro boys for years! Not like they aret great cars; they just won't ever hear it from me. :p
