That is an awesome idea...I like!Coulro wrote:Thanks :D
Spydesense, I just drizzled the handle with glue from a hot glue gun then dropped it in purple dye. After the handle was dyed I peeled the glue off to reveal the pattern. Super easy and took less than ten minutes in total.
I used RIT dye, I tried to dye it green with another brand of dye from walmart and it had no effect on the frn.
Hi Coulro,Coulro wrote:Thanks :D
Jazz, the glue was in strings and was pretty easy to pick off, heating it under hot water seemed to make the glue more pliable and easier to remove.
