rit dye for g10
Heespharm
#41
Post by Heespharm »
kens73 wrote:since its pink, i'd go with a nice bloody red!
Should work just fine.
+1
JNewell
#42
Post by JNewell »
Heespharm wrote:Always use powdered
Thanks. I tried liquid on the gray G10 and got absolutely NOWHERE. :D
Jay_Ev
#43
Post by Jay_Ev »
JNewell wrote:Thanks. I tried liquid on the gray G10 and got absolutely NOWHERE. :D
I'm sorry you didn't have good luck:
JNewell
#44
Post by JNewell »
Jay, was that liquid????? If so, I need a bang-head-on-wall emoticon. I tried 2x with very careful degreasing and cleaning... :o :( :confused:
Jay_Ev wrote:I'm sorry you didn't have good luck:
BAL
#45
Post by BAL »
Chris_H wrote:It looks more like flannel than camo to me with the red -- I like it! :D
That's exactly what I thought Chris, and I like it as well. I would be afraid to do that myself, but i like the regular digicam. I would proably buy anything in digicam.
Mako109
#46
Post by Mako109 »
I'm thinking of trying RIT on a knife with pinned construction, so I cannot remove the G10 scales. Anyone have experience immersing the entire knife into the dye solution and the effect on all metal parts? From what I'm reading here the powdered RIT requires the addition of salt to the solution which concerns me.
kens73
#47
Post by kens73 »
I dyed mine with no salt :eek:
worked just fine
Lost count ... :spyder: :spyder: :spyder:
Super Blue Lover
Heespharm
#48
Post by Heespharm »
Mako109 wrote:I'm thinking of trying RIT on a knife with pinned construction, so I cannot remove the G10 scales. Anyone have experience immersing the entire knife into the dye solution and the effect on all metal parts? From what I'm reading here the powdered RIT requires the addition of salt to the solution which concerns me.
I don't think the pinned metal parts will be affected... Just dry it really well... The paper clips I used were not affected by the dye at all
Mako109
#49
Post by Mako109 »
Thanks for the responses guys. I think I'll give it a go :)
EZ Bake
#50
Post by EZ Bake »
Started out as a Foliage Green CTS-XHP model.
Don't know if I'm catching the true color (Royal Blue) with my crappy cell phone camera, but I'm too lazy to get out the good camera and try and get some better lighting, so this is all you get:
Going to be a user now - pretty happy with it overall. Removed the scales, used Royal Blue liquid RIT (because no one in my entire stupid county had the powder in orange -that's what I originally wanted to do) and put them on a couple of wire-coat-hanger make-shift holders and boiled a pot of water with the liquid Dye and some salt. Then set the pot to simmer and put the scales in with the hanger (washed with dish soap first and handled with rubber gloves to prevent oils from coming into contact with the scales). Rinsed afterward and oiled with some CLP Break-Free (because it's what I had handy), and it looked pretty darn good (I think - at least for my first time). About 1 hour of work and I had some Royal-blue (almost purple) scales.
jimnolimit
#51
Post by jimnolimit »
EZ-Bake, that looks real good to me. it makes me want to give royal blue a try on my M4 manix2.
question: how long ago did you dye the scales? i'm interested in long term durability of the dye.
Rwb1500
#52
Post by Rwb1500 »
WalzAaronFFG wrote:This is royal blue RIT powder on yellow FRN Ladybug Hawkbill Salt
I think my Tasman Salt is getting a bath tomorrow...
EZ Bake
#53
Post by EZ Bake »
jimnolimit wrote:EZ-Bake, that looks real good to me. it makes me want to give royal blue a try on my M4 manix2.
I dyed it for about 20 minutes or so. It seems to be holding up pretty well so far with rubbing and scratching just to test it out.
feed_the_animals
#54
Post by feed_the_animals »
I rit dyed my Foliage Barong royal blue. Even without subjection to water, it will wear some. Under the bend of the pocket clip it is still fairly bright blue, but everywhere else it has faded to a darker denim color like sun bleached carpet. Foliage is showing through on edges.
Basically, Rit is not permanent and a blue will never quite have the bright quality of the blue G10 of Manix, Sage, Para 2. Once I have the time I'll pick up some abrasives and a mask and learn to mill G10; that's the only lasting solution.
Rwb1500
Necropost, I know but..
#55
Post by Rwb1500 »
JayTeeEmEm wrote:Image
This is from Missing Digits on BF. Not sure about the red but I think blue would look ok with the camo pattern thru it.
I think this looks absolutely awesome. I might try it. Either red or blue.
jkh
#56
Post by jkh »
Rwb1500 wrote:I think this looks absolutely awesome. I might try it. Either red or blue.
have you tried it yet? this is tempting but i have no experience in doing any of this.. =/ i would like to see a blue digicamo tho!
Rwb1500
#57
Post by Rwb1500 »
jkh wrote:have you tried it yet? this is tempting but i have no experience in doing any of this.. =/ i would like to see a blue digicamo tho!
Haven't worked up the uh, fortitude to try the Paramilitary yet, I've done a good bit of FRN though.
RoBoTech
#58
Post by RoBoTech »
wvguy8258 wrote:It would be sweet if all knives also came in white g-10 that could be easily dyed.
I have a set of .080 white G-10 to fit a good size folder.
But after my experience with white G-7, I am putting off the white G-10 for a while.
Papa_K
#59
Post by Papa_K »
I like that Red Digi-Flannel.
There's a youtube video of someone dying a G10 Dragonfly and an FRN Ladybug.
Not sure if it's the recommended procedure, but he didn't take either knife apart to dye them.
Link: http://www.youtube.com/watch?v=jb5g3xolWA4
I may try dying Blue G-10 to Navy Blue.
Rwb1500
#60
Post by Rwb1500 »
Dr. Snubnose wrote:So I got some Pink G-10 Handles I need another color...besides the obvious Black and Brown....what other colors could I possibility get and which color dye to get there...Doc :)
Did you ever end up dying the pink Doc? I have a pink Manix and I'm itching to dye it.
