H-1 steel destined for greater deployment...?
I just received a SpyderEdge Atlantic Salt H-1, the first of two recent orders from this unique series of knives (Dragonfly should arrive next). The H-1 steel is remarkably sharp out of the box, and though it dulls more quickly than, say, S30V, the stuff is also quite easy to sharpen. I like this knife very much; its lightness is a plus for everyday carry, while the rust-proof blade provides genuine peace of mind in lousy conditions, where a fellow just can't help getting wet. Finally, the high-visibility yellow FRN handle certainly makes this folder stand out among my almost uniformly black collection....
Gentlemen of the forum: do any among you well-connected insiders know if Spyderco intends to use the rust-proof H-1 steel in something resembling a premium knife, with proper liners and a pivot-point adjustment screw?
I remember reading that H-1 is used only on knives that are 100% rust-proof. That would include: blade, liners, screws, lock, pivot, clip, lanyard tube, washers, standoffs, etc...
I don't see it being used on a premium knife unless all of the above mentioned components are made rust-proof as well.
- Minibear453
- The Deacon
Really doubt Spyderco will build one the way you suggest, for the reasons already mentioned. You could hunt around for a Mariner Salt, it's the closest thing to a premium H-1 knife, although it lacks an screw pivot. Your other alternative would be to have someone rebuild one of the Salt series for you. This Atlantic has ti liners and backstrap, a modified tip, and stabilized birdseye maple scales.
[CENTER]
[/CENTER]
[CENTER]
I think Sal commented on another thread about the H-1 and how it must be designed "from the ground up" Most other metals don't fare too well in saltwater. If you can use a fixed blade, the Aqua Salt is a thing of beauty. They are becoming harder to find but still available. Paul you sure have some beautiful knives. :)
Clovisc and I have been lobbying for this for some time. Jason made some specific design suggestions and I contributed a name, "Salish Salt", from the Salish Sea which is Puget Sound and surrounding waters. No indication from Spyderco yet of a premium H-1 folder.Highlander8 wrote: Gentlemen of the forum: do any among you well-connected insiders know if Spyderco intends to use the rust-proof H-1 steel in something resembling a premium knife, with proper liners and a pivot-point adjustment screw?
It was our mutual friend Clovisc who originally lobbied for the H-1 Spyderhawk that did come to fruition thank GOD.>> I was amazed that Spyderco went ahead and reintroduced the Spyderhawk in H-1. I'm now EDCing my SE H-1 Spyderhawk since I lost my old favorite standby G-10 Harpy.Sequimite wrote:Clovisc and I have been lobbying for this for some time. Jason made some specific design suggestions and I contributed a name, "Salish Salt", from the Salish Sea which is Puget Sound and surrounding waters. No indication from Spyderco yet of a premium H-1 folder.
H-1 truly has a multi-faceted potential for all kinds of specialty cutlery. So far I'm very pleased with the H-1 Spyders that I own and use. And by the way I don't have any H-1 collector pieces>> they are all EDC blades that I rotate from time to time. H-1 is truly meant to be used and used hard. It's potential is going to go in many different directions.
Personally at the very top of my H-1 want list would be a full or medium sized Dyad model with a yellow G-10 handle. I also want a new C-44 Dyad in one of the new super steels as well but an H-1 Dyad would really be a "user's dream folder"
Right, and that would make the result quite costly...; but do you think that Spyderco would consider building a $200-$300 special edition, with all of your necessary component parts made from H-1, or would this produce a prohibitively expensive knife?Jay_Ev wrote:I remember reading that H-1 is used only on knives that are 100% rust-proof. That would include: blade, liners, screws, lock, pivot, clip, lanyard tube, washers, standoffs, etc...
Nothing is impossible but a knife of that fancy-tude in H1 is probably less likely than some.Highlander8 wrote:Right, and that would make the result quite costly...; but do you think that Spyderco would consider building a $200-$300 special edition, with all of your necessary component parts made from H-1, or would this produce a prohibitively expensive knife?
As a baby step I think seeing a g10 Salt would be a step in the right direction. No titanium nested liners or anything, just simple G10 and lockback components. FRN works amazing but some might be willing to pay a tad more for something that feels a bit more classy.
Personally, I'd love to see a UKPK FRN in H1 ... there haven't been any H1 non-lockers yet :) I do a bit of beach-combing and it would be nice to be able to take a Spydie down and use it without worrying about rusting-out the internals.
My spydies: Squeak, Tenacious, Terzuola, D'Allara, UKPK CF peel-ply pre-production, UKPK CF smooth pre-production, UKPK G10 orange leaf-blade, UKPK FRN grey drop-point, UKPK FRN maroon leaf-blade, Bug ... all PE blades :)
- The Deacon
The other factor working against a premium H-1 model, IMHO, is that H-1 is at its best when serrated, and Spyderco has found that higher end serrated knives sell very poorly.
I'm not following you. How is it that Salts sell at similar prices to their VG-10 counterparts if they have to be prohibitively expensive?Highlander8 wrote:Right, and that would make the result quite costly...; but do you think that Spyderco would consider building a $200-$300 special edition, with all of your necessary component parts made from H-1, or would this produce a prohibitively expensive knife?
That would indicate to me that a custom design would cost about the same as an equivalent VG-10 custom design.
The only negtive issue I can see is that the tendency for H-1 blades to scratch might be more of a turn off in a higher priced knife.
Endura - $104.95
Pacific Salt - $109.95
- The Deacon
Think you're leaving out the "R&D factor" All the Salt folder used existing handles and blade shapes and cost approximately the same as their VG-10 counterparts. OTOH, look as how much less expensive the Schempp Rock is compared with the Rock Salt. Am sure that's not a totally fair comparison either, my gut tells me there have to be other factors at work, but some of it has to be differences in material and labor costs.Sequimite wrote:I'm not following you. How is it that Salts sell at similar prices to their VG-10 counterparts if they have to be prohibitively expensive?
The H1 steel and supporting Salt hardware have to be more expensive than the equivalent VG10 model. Otherwise it would be far cheaper.
As Paul said they use older molds which have had time to pay themselves off. Also, Salt models lack liners and FFG treatment which adds to material and labor costs. Your picture even shows extra attachment points and tapped holes for 4-way clip mounting.
This isn't to say a Pacific Salt isn't just as good of a knife as an Endura4. Just differences that add up.
