What lubes do you use? & why?
Thanks Patrick!G10KnifeNut wrote:Research tuf-glide and I think you'll be happy. I just read reviews from gun owners who say after its dry, dirt and dust seem to just fall right off, it doesn't collect at all even inside the firearm :) And everyone knows how dirty guns get on the inside
CF Balance, CF Caly3 ZDP, Caly 3.5 SB, CAT 440C, Chaparral, Orange Jigged Damascus Delica, Blue Jigged Damascus Delica, BRG Delica ZDP(SOON TO BE G-10!), FG G-10 DragonFly, Gayle Bradley, 2012 Jester, H1 Ladybug Salt Hawkbill w/G-10 scales, Tan Manix 2 M4, MoonGlow Manix 2, C22CF Michael Walker, BRN Millie XHP, Native 5, PM2, All Black PM2, Gray PM2 20CP, Blue PM2 M390, Sage 1, Sage 2, Sage 4, Terzuola, CF Stretch ZDP, UKPK Drop Point
- jackknifeh
Hijacking the subject for a minute. Sorry.G10KnifeNut wrote:Dude I CANNOT BELIEVE that just happend!!!! AHHHHHHH >jeeeez
I just typed up this super long great reply then I tried to add a link and it deleted it alllll! anyways, you should've asked me Phillip! :D Get mineral oil for a few bucks at the local food store. Use for blades that may touch food :) lifetime supply for a few bucks is a steal!
Then get Tuf-Glide! The BEST stuff on the market :) Leaves a protective dry lube film that will not wash or wipe off! Leaves your knives or anything else it touches protected for awhile. Just re-apply every few months depending on how much use they get! Now before the links destroy this post, I'll add another post with links for a GREAT price where you can decide which bottle best fits your needs :)
I have a new PC now but my old one would restart by itself every so often. On a couple of occasions I had typed a long post and the PC restarted. So, I started using MS Word to type anything that I thought would be long. Or if I saw that I was going to type more than I planned I copied and pasted it into a Word doc. That way I could save what I typed every minute or so and if the PC restarted I was ok. If you did something like that and copied the text into the post and the post got deleted you would still have your post in a MS Word file. Of course you could use the text editor or Wordpad that comes with Windows if you use Windows. Any text program should work.
Just a thought that did save my butt (and fingers) a few times.
Ok, now the thread is un-hijacked. :D
Jack
- Simple Man
Here's more than ya asked for, but what I use;
Quick Release - just got some, knife lube
Militec-1 - just may get replaced by QR
CorrosionX - for protection/wiping down, knife and gun GOOD STUFF
Breakfree CLP - firearm general cleaning (HOPPES 9 to heavy clean)
Rem-Oil - for used knife cleaning/restoring and non knife higher quality stuff
Ballistol - for door hinges, stinks to much for anything else
WD-40 - for low quality cleaning and sticker removal
Kroil - soak to remove rusted bolts
Mineral oil - for strop compound application
Romans 8:31 ....If God is for us, who can be against us? - <><
The Spyderco hole is a rotating mechanical assembly of one part.
".....tractors don't have to look like Ferraris" -Sal
- razorsharp
- Simple Man
you guys are funny. Thanks for the input Simple Man.
back off topic about computers. Ihave had the same thing happen G10KN. I think it has to something to do with internet explorer. ie has a lot of bugs i think. I usually copy long posts so this doesnt happen.
From what you guys have mentioned; I think I am going to buy a variety and see what works best for me. I appreciate all the input. At some point in time I will comment on my findings between the differnt products
- Simple Man
Hey, as long as you know the limitations, more power to you.
I use mine for food also, and even with the laundry list of stuff used, I just wipe it off, before and after and have never had problems. Any that might be ingested is too minute to be of issue.
Fact of the matter is that I mostly clean my knives in/near the kitchen with a toothbrush (one I specifically bought for that task). Pour a couple of drops of olive oil on the counter dip a toothpick in it and apply it. That way I get a little as needed on the spot that needs it. The more you put on the more there is to attract stuff you don't want there...
- phillipsted
As I mentioned, I use primarily Tuf-glide and Militec for protection and lubrication. But a friend of mine (who is an avid bicycler) told me he uses Finish Line Ceramic Wax Dry lube
http://www.finishlineusa.com/products/c ... x_lube.htm
I've tried it on a couple of my knives, and it is interesting stuff. It dries to a micro-thin solid waxy film and seems to last a lot longer than the thinner oil-based lubes - and it provides a silky smooth feeling. Not completely sold on it yet, but it is pretty good - and should be available at your local bike shop.
TedP
TedP
- jackknifeh
I tried Finish Line (not the ceramic) wax lube. One thing I didn't like has nothing to do with how it works. I got some on the handle of a knife that had small grooves in it and after it dried it looked bad and was a little hard to get off. I figured it would be good for keeping dirt out. I mean, what would get dirtier than a bicycle chain? Not many things I'd think. Maybe that stuff would be good for knives in a really dirty environment. Construction site, etc. The lubrication aspect was very good. It didn't attract dust or dirt which is great. The pivot is the only place you would want to use wax lubes. I've heard "White Lightning" is another good one. You would need something else on the blade and other metal for corrosion resistance.phillipsted wrote:As I mentioned, I use primarily Tuf-glide and Militec for protection and lubrication. But a friend of mine (who is an avid bicycler) told me he uses Finish Line Ceramic Wax Dry lube
TedP
Jack
- Guy Vanderveken
- Lord vader
Mineral oil can be purchased in just about any drug/pharmacy stores or Walmart.I use mineral oil on any of my folding knives that come in contact with food. Mineral oil has no detectable odor,and it`s colorless.The same Mineral oil is also taken internally as a laxative.Shakyamuni wrote:Some people have mentioned Mineral Oil, which I could not find in a store.
I noticed that the 2 ingredients to Baby Oil are Mineral Oil and fragrance. So if you don't mind your knife smelling like a baby, you could use that instead.
