Black Pocket Clip & Screws for Yojimbo 2
Hey everyone,
I just bought a brand new / older style plain black pocket clip (and 3 black screws) made to fit an Endura / Delica for use on my Yojimbo 2.
Also it does not have the hole in the middle either.
dwayne1341
dwayne1341
I did the same, black screws and all, thanks to Mike J's tip. I also blacked out the last torx screw head (the one right above the clip and is exposed when the knife is clipped to your pocket) with "Super Black" (flat). Looks much better now :) I've used SB to touch up small nicks on my guns with pretty good results. Hoping it will last on the torx screw head. Put three coats on and EDC'd the Yo2 for a week, so far so good. No big deal if it eventually chips off as it takes seconds to reapply.
- DemskeetSkeet
Pictures?
My :spyder: Collection: http://www.youtube.com/watch?v=3B4iA4SJr9Q
Spyderco Dialex Junior Video:
http://www.youtube.com/watch?v=GAojHJahvzY
EDCF MoonGlow Manix2 Video:
http://www.youtube.com/watch?v=daF_13D4VVc
Spyderco Lava Video:
http://www.youtube.com/watch?v=EfsEKJkE ... ture=g-upl
- DemskeetSkeet
Thanks for the pictures CevTV, looks good!
- fifthprofession47
I just received four black Endura replacement clips from the Spyderco Factory Outlet Store for my Yo2's.
"One is none and two is one"
Martial Blade Concepts - Certified Instructor
http://www.martialbladeconcepts.com/
To All:
If you want a black clip AND black screws on your Yo2, here's a little additional info:
The Endura clip will fit on the Yo2; however, the replacement screws that come with the Endura clip kit are metric screws because the knife is Japanese made. The Yo2's screws are English standard. If you put the Endura screws in the Yo2, it won't be a proper fit.
If you want black screws and a black clip, your best bet is to order a replacement clip kit for the Para Military2 black blade. This will allow you to swap the clip and the screws for an all-black look. The Manix2 also uses the same clip and screw thread, but uses bigger, beefier T-8 screw heads instead of the more common T-6. However, since the Manix2 is stacked construction rather than nested, it uses longer screws than the Yo2. The screws will extend into the slot on the inside of the handle. This won't matter for tip-up carry, but it's a no-go for tip-down since the screws will hit the ricasso and bind the blade.
You can always shorten the Manix2 screws... or, carry tip-up the way I do...
Stay safe,
Mike
Stay safe,
Mike
Michael Janich
Spyderco Special Projects Coordinator
Founder and Lead Instructor, Martial Blade Concepts
- fifthprofession47
Thanks, Mike!Michael Janich wrote:To All:
Stay safe,
Mike
- Rockcrawler
