frn UKPK
Yes it is. It will work just fine but it is not near as strong as my G10 models. In fact, I sent my FRN CTS-BD1 to Spyderco because this one in Black was weaker than my earlier Blue and Gray models. Spyderco sent me a note back with it that it met the specs for this model. I have used it and had no problems but I would prefer a stronger back spring. I understand Spyderco has plans to update these models with a stronger back spring later on. Not sure just when.
RKH
RKH
The ukpk rocks. I never thought I'd be interested, but now that I have a few I find that I carry one most of the time!
Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure... than to rank with those poor spirits who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat.
Theodore Roosevelt
Theodore Roosevelt
I imagine it will be strong enough.
Here is what I did. I bought the Squeak first. The Squeak has the same spring and a shorter blade, so the spring should seem stronger. With the Squeak I can feel the spring and determine if I think a longer blade with the same spring will work good.
I think it will, but I think the Squeak will tide me over until the stronger spring comes out. :P
-Brian
A distinguished lurker.
I have an frn ctsbd1 ukpk and I love it. I dont feel the spring is to weak. Plus you have a nice finger choil there to stop the blade from closing. Unless you guys mean stronger lock for when its closed. Also the blade has a mid stopping point. When the blade is perpendicular to the handle it stops with some resistance from the lock.
Are the g10 slipits that much harder to open and close?
Manix 2 DLC, Delica 4 FFG, Ladybug 3,County Comm H1 Ladybug 3 , Endura 4 FFG G10, C94 UKPK Leaf, Atlantic Salt, Military Camo DLC,Sage 1 Para 2 DLC, Delica 4.
- The Deacon
Keep in mind that initial observations about the strength of the FRN UKPK's spring came from people who owned the G-10 version. While the FRN one's spring isn't as strong, it's not dangerously weak, and the tradeoff is that it's easier to open as well as to close. Personally, the only Spyderco I've ever owned that I would not trust my fingers to is the T-Mag and even it has its devotees.
The new ones are Cts-Bd1. Its a great steel. The American version of Gin2.nehctik wrote:Suprised though as the blades marked bd1, I thought the coloured frn ukpk's were gin1
Deacon summed it up very well on spring strenghts of the FRN and the G10 UKPKs. My G10 are much stronger than the FRN and that it why a noticed the weaker spring in the FRN models. And like I said earlier I have had no problems with the FRN models as the design keeps the knife from folding. I got a Squeak about a month a go and noticed the stronger spring. The Squeak is another fine knife too.
RKH
RKH
Of course, compared to other slipjoint knives out there...even the G10 is weak. Swiss army knives have so much tension, both blade open and closed. But thats just fine, because if it was that strong, I wouldn't be able to open it with one hand.rkh wrote:Deacon summed it up very well on spring strenghts of the FRN and the G10 UKPKs. My G10 are much stronger than the FRN and that it why a noticed the weaker spring in the FRN models. And like I said earlier I have had no problems with the FRN models as the design keeps the knife from folding. I got a Squeak about a month a go and noticed the stronger spring. The Squeak is another fine knife too.
RKH
I just aquierd a UKPK. :spyder: So far I like it a lot. The only gripe that I have is that it didn't come nearly as sharp as my other Spyderco's. It was BNIB, so I had assumed that it would be as sharp as everyother Sydy I have ever owned, but it's not the case. That is the only little thing that I found disturbing. Other than that I like the knife a lot.
