Slash wrote:Yeah, it was meant to be a joke. Guess you didn't get it.
You tried to be funny and failed and your post just ended up being irrelevant in a thread about coarse vs.polished edges.
Slash wrote:Cutting perfomance as in you need to cut stuff all day long?
Cutting performance as in cutting stuff with the least force needed to be applied at the handle. You probably are thinking of edge holding....
Slash wrote:Unless you're a butcher or chef then I don't think you're cutting stuff all day long. If so then you're most certainly not using a polish edge blade.
Yeh, I actually worked at a farm where I had to cut stuff all day.
Slash wrote:For daily utility cutting tasks you're most likely using a serrated edge or carrying a stone/steel to touch up that plain edge. Thus, no polished edge here either.
Nope, serrated edges don't work with fine work like what I need to do with bamboo. I also don't want to stop to sharpen every few cuts.
Slash wrote:So, really a polished edge is just nice for pics and displaying, etc...
Again, nope. A polished edge lasts longer for me compared to a coarse edge. Coarse edge slices better but a polished edge push cuts better and that's what you need when working with bamboo. I also cut a lot of green wood(diseased branches) and polished edges glide through where you'd have to saw with a coarse edge.
Slash wrote:Maybe I'm wrong. But, I really can't think of any tasks a knife would need to be polished?
Think wood working.But since we are all knife nuts here, it's not just about "need". It's about preference and cutting performance. One person here has to cut tires all day, he needs cutting performance for that where a coarse edge just can cut it.
Just because your thinking and experience is limited does not mean that everybody has to think like you. :p
The way you talk, you probably don't use a knife for cutting much at all. I guess you can't think of things a polished edge will do because you just pry and stab with your knife.
