The original Li'l Temp is the only thing that came to mind for me. Unless you want a wharncliff, in which case the Yojimbo/Yo 2 fits the bill.
I heard the Li'l Temp 2 switch from comp. to RIL lock, very disappointing if true. If it was a frame comp lock and I misunderstood, that's cool. But the comp lock is a defining feature of the Li'l Temp IMO.
You could probably buy a para 1 on the cheap then modify it to make it smaller. You could even go as far as cutting the handle down some along with the blade because of the open construction and move the lanyard hole up or remove it all together
VashHash wrote:You could probably buy a para 1 on the cheap then modify it to make it smaller. You could even go as far as cutting the handle down some along with the blade because of the open construction and move the lanyard hole up or remove it all together
Ive looked into shortening the Para on both ends, i decided it wasnt worth the hassle. There isnt much you can remove from the butt of the handle because of how far down the blade is when closed...and thats considering i already took 1/8 inch off the tip of my blade.
