Had some fun with RIT dye this morning. I decided to change my Tasman from yellow to orange. Used about 3/4 a bag of powdered Sunshine Orange and left the knife in for about 25-30 seconds. I'm happy with the final result :)
![Image](http://i762.photobucket.com/albums/xx266/nomad32_2009/DSC_0977-1.jpg?t=1302884326)
![Image](http://i762.photobucket.com/albums/xx266/nomad32_2009/DSC_0991.jpg?t=1302884328)
Thanks for looking,
Canis
I wasn't thinking about the steel being H-1. I feel very comfortable using all my Spydercos in rain or water. I drown them in Tuf-Glide when they come out of the box, then normal care after that. I always dry them after I clean them out as soon as I can after I rinse them off. How long does it take for the dye to dry? I would want to dry any excess water as soon as possible with a hair drier. Does the dye not stick to steel at all (blade, lock bar, washers, etc.)?CanisMajor wrote:Yeah I put the entire knife in. I just held the tip of the blade and moved the knife around in the dye. Took the clip off as well. Don't think you can dye a black handle to any color. If you start with yellow, it will work. Others got OD green and other colors. I'm sure it could have gone darker orange, but I liked the color after about 30 seconds. Just make sure you have something deep enough that can fit the entire handle and some of the blade in. I used a fairly large Mason Jar. Put the powdered dye in, then poured boiling water in the jar till it almost hit the top. Stired with a plastic spoon, then held the knife in. Just be sure to check often so it doesn't get past the color you want.
Canis
Exactly what I did.pmbspyder wrote:Nice knife! Well done with the orange color, looks great to me.
Jack - you can't dye black frn. Yellow works great, as does white and a few other colors. You can place the whole knife in the solution even if it's not H1, it won't stain any of the steel (just remove the clips so that part of the knife gets dyed). After you get your color, scrub it with a toothbrush and some dishsoap under running water, let it air dry for a while, then hairdryer, then compressed air. If you're going to do it, you should check out my RIT dye thread (I dyed a spyderhawk and ukpk), I posted a brief list of important do's and don'ts. Hope it helps.
And again, nice looking knife! Makes my black pe tasman look so mundane!
I got mine at Hobbly Lobby, but I've heard Target and Wal-mart have it as well.camokid wrote:Where did you get the dye from?
Don't believe it will, I haven't really done anything with it yet. There is a huge thread of RIT dye Spydercos.Michael Cook wrote: :spyder: Will the rit dye rub off in a sweaty hand? :spyder:
