Sal's Casual Bombshell Thread
- SkullBouncer
:spyder: :spyder: Potential realization of a New CHINOOK IV gets my vote early and often. :spyder: :spyder:
Even with the potential evolution and design / metallurgical / heavier duty improvements to reach this hypothetical stage -- plus royalties (J.A.K) factoring all in were to see the light of day but resulted in her carrying a substantially heftier price tag, I'd GLADLY pay in excess of $300.00 MSRP.
Speaking personally, if by way of a resurgence of the earlier 'battletank' Chinook concept -- only taking advantage of new availabilities re: 'exotic' steels than incorporated before were to be taken under consideration and resulted even in a sprint run -- WOWWW. :D
(...CPM S90V, maybe ZDP 189; a return to Solid liners, maybe backtracking from FFG's less overall blade mass as with the III; further advancements in evolving blade profile; G10 scales retained + more massive construction in a resurrected CHINOOK (IV), I believe altogether has a bigger potential for securing a loyal, enduring market niche than may be otherwise presumed. Light SD knives IMHO aren't necessarily "all that" ALWAYS.)
STAY SHARP --
:spyder: SB :spyder:
STAY SHARP --
Question for Sal re an H1 model for pilots
Sal,sal wrote:simply greater capacity. We're making a model for the Naval and Airforce pilots and greater capacity was needed.
What model is this, please?
- SkullBouncer
I'm gonna take a WAG and say Moran DP...
I think Michael Janich posted in a forum or in a video about the Moran DP (FB02) being modified to meet U.S. Military pilots' survival knife needs.flash900 wrote:Sal,
Again, this is my recollection of the answer to your question. Let's hope Sal or MJ sees our posts and sets the record straight.
"All your :spyder: are belong to us."
** WTC # 1032 1533 **
yablanowitz
I suspect the model being referred to is the black blade Pacific Salt, since it was one of those being converted to screw hardware to increase manufacturing capacity, and I recall TazKristi mentioning it was being made for the military initially.
Perhaps this is what you meant, but I recall the change to screws as being a government requirement.yablanowitz wrote:I suspect the model being referred to is the black blade Pacific Salt, since it was one of those being converted to screw hardware to increase manufacturing capacity, and I recall TazKristi mentioning it was being made for the military initially.
Sal's comment on Para2 CF/ S30V and possibility of more sprints
sal wrote:It's a very nice combinationof materials on a very practical design.
Naturally the ideal number is enough to please all that want one and no more. It's a very challenging number to guess, especially when, as mentioned, it becomes a commodity to sell rather than a very nice knife to experience.
I would guess that you'll see more carbon fiber, maybe a different color, but probably with a different exotic steel.
- mark greenman
For all you Schempp Rock Salt lovers:
Sounds like a nice alternative to the Temp 2. :D I wonder how the price point will be, FRN handle?sal wrote:we changed the new ed schempp rock salt into a full flat grind vg-10 model. (same handle, same sheath). Made for wilderness use. I think we're calling it the "schempp rock". Should be all the "toughness" you would need for a fairly large knife in the field.
If you are going to go out in the bush, bring your tough knife. If you can't remember to bring a tough knife, and you have to use your folder, if it's a spyderco, you'll have to remember it's a folding knife made to cut.
i think they're tougher than you think.
Sal
:spyder: Come chat with us on IRC at #SharpThings! :spyder:
:spyder: Check out the SharpThings.net website too! :spyder:
Tactical Edge
Affordable I hope, considering I missed out on the Rock Salt and have searched everywhere for one only to find them priced at above $300!!!Creepo wrote:Sounds like a nice alternative to the Temp 2. :D I wonder how the price point will be, FRN handle?
Plus I think the FFG has great potential as a wilderness/survival knife. And with the blade material being VG-10 it shouldn't be too much of a worry to re-sharpen. Can't wait!!!
By failing to prepare, you are preparing to fail
yablanowitz
I'm guessing everyone's already seen the prototype for the Native SLIPIT over on British Blades, but just in case: http://www.britishblades.com/forums/sho ... -Slipjoint
