Carpenter Steel Question
Does anybody have a review on the ctx-xhp carpenter steel? I was wondering how it compared to s30v? Im also trying to get a feel for how their steels compare to that of crucibles. Are they better, worse or about the same. Please help to educate me on this. Thanks
If you search this forum you should find plenty of articles - but the name is CTS-XHP
It seems to be very well-liked generally ... I'd guess better than CPM-S30V but not sure how it would edge-hold compared to CPM-S90V :)
My spydies: Squeak, Tenacious, Terzuola, D'Allara, UKPK CF peel-ply pre-production, UKPK CF smooth pre-production, UKPK G10 orange leaf-blade, UKPK FRN grey drop-point, UKPK FRN maroon leaf-blade, Bug ... all PE blades :)
So far it seems to be a smoother steel (finer grain, better finish) than CPM-S30V. It also seems to hold a hair whittling edge longer than S30V, which always seemed to lose hair whittling quickly, then hold a working edge for a long time.
I've only had it about a week, and haven't had to sharpen it yet, but just what I've noticed so far.
- The Mastiff
I'm not really overly enamored by that CTS alloy chart. It has the XHP, which is basicly D2 stainless as being more wear resistant than their CTS version of BG42 ( CTS B75). According to Latrobe and their charts BG42 at RC 60 is both tougher and more wear resistant than D2 at RC 62. By a fairly large amount.
CTS XHP does seem to be a bit tougher and more wear resistant than ingot D2, but I personally feel decently hard BG42 will out wear D2, and XHP as well.
As far as S30V goes I'd guess it depends on hardness to an extent. At RC 60 I'd place it as more resistant to wear than XHP due to that vanadium. That all day working edge that people talk about anyway. I'd place the wear resistance of S30V below both 204P and 20CP though.
All guessing with no real experience but trying to go by various foundry graphs and stuff. :)
In other words, I'm guessing but don't know Jack! My experience with both 390PM and 20CV leads me to believe that the similar 204P outlasts S30V, as does S90V ( and likely the similar 20CP)
Do I have a knack for confusing things or what? :)
The Mastiff wrote:I'm not really overly enamored by that CTS alloy chart. It has the XHP, which is basicly D2 stainless as being more wear resistant than their CTS version of BG42 ( CTS B75). According to Latrobe and their charts BG42 at RC 60 is both tougher and more wear resistant than D2 at RC 62. By a fairly large amount.
We won't really know for sure until we see blades in the steels.
I tested CTS-BD1 on rope and wasn't impressed with the edge holding at all on that steel compared to VG-10 and AUS-8A.
- The Mastiff
I agree completely with you Jim.We won't really know for sure until we see blades in the steels.
Youcan only do so much with manufacturer graphs such as these: http://www.latrobesteel.com/assets/docu ... Steels.pdf
( *note 14/4 steel is Latrobe's name for their version of 154cm/ats34 )
Carpenters graph with S30vs D2: http://www.crucible.com/PDFs%5CDataShee ... 202010.pdf
It's fun to read this stuff though.
Edge Retention (CATRA Testing Relative to 440C) ( from PDF)
Grade %
CPM S30V 145
154CM 120
440C 100
Note Latrobe has 20Cv at 180% in their version of this graph.
I do stand by my statements about BG42 vs. D2 though. In my experience it's more wear resistant and has better edge stability.
Another issue we seem to run into is in some cases steels with high edge stability can feel or stay sharper over what are actually more wear resistant steels in the short term due to the ( insert reason).
The high vanadium steels ( 4% and up) may not feel as sharp as say 13C , but will really pull ahead when working on such media as carpet, ropes, dirty stuff containing sand & gravel, etc.
I guess I'm saying that we collectively have a ways to go yet. That's the good news though. If we knew everything we'd lose interest. :)
The Mastiff wrote:I agree completely with you Jim.
Grade %
CPM S30V 145
154CM 120
440C 100
I have done some rope testing and found that M390, ZDP and CPM-154 (62 RC) (Not 154cm) rock at cutting rope. That's using a scale to measure downward force and stopping at 20 LBS using slicing cuts. Checking every 20 cuts.
Depends on how hard S30V is on the RC scale.jzmtl wrote:Pure wear resistance wise not many steels can beat S30V. Speaking from manually reprofiling on a diamond stone, not even ZDP is as much pain in the butt as S30V, and CPM D2 is quite a bit easier. VG10 is like butter compare to those.
Take S30V much under 60 RC and it feels like butter, but at +60 RC it's a lot better and will do what it's supposed to do.
There is a huge difference in S30V at 58 RC and 62 RC.
Even with S30V at 62 RC ZDP-189, M390, and CPM-154 (62 RC) (that's not 154cm) will kill it in edge retention, it's not even close.
Once I get the Para 2 Sprints I will enter them in my testing database cutting rope, it will be intersting to see how CPM S90V and CTS-20P compare.
